Go Back   Automotive Forums Car Chat > Mazda > 6
Old 07-09-2012, 05:15 PM
00Bravada 00Bravada is offline
Power windows not working properly.
I just replaced the battery. Now the auto down and up on my drivers window isn't working. It does work if I hold it down or up. Also I can not control the front passenger window from the drivers side, it does work on the passenger door though. All other windows work and can be controlled from drivers door. Anyone have any ideas as to what it might be? Oh yeah it is a 2006 Mazda6, V6
Old 07-09-2012, 08:30 PM
Re: Power windows not working properly.
Figured it out. You have to go through steps after replacing the battery to get windows to work properly.
1. start your car.
2. press the affected power window switch down until the window is fully down
3. pull the affected power window switch up 1 click (manual up, not auto)
4. keep the switch pulled in manual up for at least 2 seconds after it closes, I heard a click at this point
5. your window should be normal now.
Will need to do this on the passenger front window control also, and then the widow will work from the driver side window control.
Old 09-26-2013, 05:01 AM
skrnoopuram skrnoopuram is offline
1. start your car.
I have a 2007 model mazda6. its one rear window is opening only half from its own button as well as driver side button. once it opened fully and could not close by any button. So forcely closed. front passenger side window is opening and closing fom its own button, but very occassionaly only opening from driver side button and not at all closing from there. driver side window and other rear window operates from both buttons. Can anyone give any idea. thanks.
Power Windows don't work joenobodyyet '96-'00 Civic 2 03-29-2012 07:07 PM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 09:25 AM
Power window no working properly Rondogg Camaro Discussions 2 06-17-2005 12:30 PM
factory power windows not working properly TRUE DEVOTION Cavalier 3 08-03-2004 07:01 PM
88 cierra power window not working Paleigh38 Cutlass Series 0 01-04-2004 04:32 PM
