Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-04-2003, 10:42 AM
accordlove accordlove is offline
new 17" wheels for 2000 accord sedan v6 ex ???
I am thinking about buy new 17" wheels for my 2000 accord 4-door V6 EX. My current wheels are 15" and tires are 205/65/15.
I want to get factory wheels which are EM-9RR or S6-SE1 alloy wheel for using honda accord 2003. You can find them on honda website.
Is it possible to install without any adjustment? I don't want to lower my car nor modify it. Some said it is okay, other said it can't. What is correct? I'm confused
Also what are good tires for 17" wheels? Is it 215/50/17 ok?
thank you.
Old 06-04-2003, 02:16 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
Yeah should be no problem, but IMO I would get some nice wheels like some ADR or something like that with some Yokohama Parada 205/40R/17 tires...thats just me, stocks look gay unless they are SI or GSR
Darrell
thegrumpysergeant.net
Old 06-04-2003, 09:45 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Check Prices
Before you buy those off Honda, make sure you check your options thoroughly. I can see official Honda wheels being an outrageous price. I'm sure you can find wheels in the style you like elsewhere, so just make sure you're not getting ripped off.
And to answer the actual question...Those wheels will fit fine. My friend has 17's on his 97' and it is very lowered, (2.25in). No problems what so ever...Accept for the ticket he just got for "turning to fast", so the cop said. lol.
Suggestion...I know you stated that you don't want to lower your car, but I'm not to sure about that. If you don't want to because of the money, then well...save up. H&R makes a great spring for your kind of purpose. I think they are called "OE Sport Springs". They only lower your car like .75in in the front, and .5in in the back. This will restore the factory ride height after you increase the wheel diameter.
Good luck!
Old 06-05-2003, 12:42 AM
please, recommend...
thanks guys.
What kind of wheels are you recommending instead of factory wheels?
Please, select a couple of wheels for me. I do not know anything except honda factory wheels.
And If I change to 17" wheels without lowering, do you mean that actually my car is going to be higher?
thanks again.
Old 06-05-2003, 03:03 PM
tynebeach tynebeach is offline
Send a message via AIM to tynebeach
for aftermarker wheels check out tirerack.com and whalentire.com and wheelmax.com . They seem to be the best price wise, and you can get wheel/tire packages.
91 Eagle Talon: Exhaust, ported turbo/mani/o2 housing, 15 psi, short route FMIC, etc..
96 Toyota Corolla: DD
Old 06-05-2003, 05:05 PM
loesch8102's Avatar
Also, check out http://www.tires.com
Yeah about the raising of the car. If you increase the wheel diameter by 2", (from 15 to 17), well that automatically raises your car 1". But due to the increase wheel size, you'll most likely go with a 50 series tire(height). The origonal tires are something like 60 series. So this lowers the car slightly, but overall it'll most likely be about .75 inches higher than stock. And Accords are offroad units to begin with (sarcasm) so you'll most likely want to drop it at least a little bit so it looks right.
My 2 favorite wheel manufacturers are Konig, and Enkei. Both offer very eye catching styles and at a decent price. Just off the top of my head I'd say your probably looking at around $1050 to $1200 for wheels and tires.
Old 06-05-2003, 06:42 PM
yeah Konig and Enkei are great, they're my 2 favorite also. But you can get a wheel and tire package from whalentire for $850 and that's with Z rated tires...
Old 06-05-2003, 07:07 PM
strodda strodda is offline
actually you would probably get smaller tires than 50 series. if you get 17's the tire size thats most usually paired with them is 205 or 215/40, which you would actually stay stock size overall. so you wouldnt raise your car at all.
Old 06-05-2003, 10:10 PM
loesch8102's Avatar
Yeah that sounds right now that I think about it. When my friend ordered his, they assumed that his car was stock and they suggested 205/50-17. So 215/40's would be about the same deal.
Old 06-07-2003, 01:10 AM
AF's #1 Bad Guy
I have a set of Excels from Wheelmax and Enkei's I love my Enkei's!!!
Darrell
2000 Accord Rear Window Malfunction pumatiger Accord/TSX/Accord Hybrid 1 08-03-2009 11:56 PM
2000 Accord sedan vs coupe headlights ROKnight Accord/TSX/Accord Hybrid 1 05-18-2006 08:05 PM
Infiniti G35 Sedan 17" wheels for sale alexgg35 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 10-13-2003 06:31 PM
Infiniti G35 Sedan 17" wheels for sale alexgg35 Altima 1 10-10-2003 05:40 PM
new 2003 factory 17" wheels for 2000 ??? accordlove Accord/TSX/Accord Hybrid 5 07-03-2003 03:34 PM
