Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 07-08-2012, 11:23 PM
miked79928 miked79928 is offline
2004 Yukon XL A/C Warm at Idle
As the title says, my 04 Yukon XL blows ice cold from both units while driving. However, at a stop light or in park the temperature of the air warms slightly. It will sometimes also blow hot. I checked the pressure using one of the units available at auto parts stores, and it was a low. I added refrigerant and the issue got a little better. I am thinking the fan clutch may be going bad? The truck doesn't overheat at all and in fact stays at mid-gauge throughout operation. Am I correct in pin-pointing the fan clutch?
Also, I know on the and up the TPS tells the pressure for each tire. Is there a way to get this same feature on my? Would it be possible through a software upgrade or replacing the entire DIC?
Old 07-08-2012, 11:34 PM
aleekat aleekat is offline
Re: 2004 Yukon XL A/C Warm at Idle
It has been over 100 lately. Back spray your rad and condenser. May help. Unless you use a thermometer in the vents, you're only guessing.
Old 07-08-2012, 11:52 PM
Thanks for the quick reply. I will try spraying the radiator and condensor first thing in the morning. I may go ahead and get a thermometer to check the temps.
Old 09-27-2012, 11:30 PM
Cusser's Avatar
Cusser Cusser is offline
If spraying/misting the AC condenser in front of the radiator helps, then your condenser is not getting adequate cooling/air flow at low speeds and idle, so sure could be the fan clutch, even if your truck doesn't overheat or run hot. Also clean off leaves and bugs off the front of the condenser.
Low Oil Pressue in 2004 Yukon XL Denali with 72000 miles DenaliDB Yukon 0 06-12-2011 10:08 AM
94 3.8 liter- rough idle, poor exceleration until warm mustang418 Mustang Problem Diagnosis 2 11-04-2010 09:45 PM
2000 Grand Am GT erratic idle when warm Help? MakeItWork Grand AM 0 06-05-2010 02:34 PM
starting/ warm idle issues thunderbirdcoupe89 Thunderbird 2 12-24-2009 11:36 AM
'01 T&C cold idle bad, warm idle okay JeffL. Caravan | Voyager 2 12-22-2004 09:27 AM
