Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-24-2009, 01:37 AM
thunderbirdcoupe89 thunderbirdcoupe89 is offline
starting/ warm idle issues
i've had this problem with my 89 for a few years now. it starts and runs fine, but developes a miss at warm idle. almost like it "loads up". on warm starts, it will turn over, start, them stumble and almost die. the vacuum gauge that I installed on my dash shows the vac start at 20, then bounce around at 15. almost every sensor is new, no trouble codes, I just put in that new engne, and replaced the fuel regulator and injectors. any ideas would help. could it be the pickup coil in the dizzy?
Old 12-24-2009, 01:44 AM
Unhappy Re: starting/ warm idle issues
oh, it also stumbles/surges under very ligh acceleration, light driving in a parking lot
Old 12-24-2009, 10:36 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Did the 89s have the 5.0L? I'm not too familiar with that engine, but I'd start with the EGR system. If the EGR valve is stuck open or commanded open when it shouldn't be it will stumble at idle and light acceleration.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Tags
3.8 , ford , idle , starting
