Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 07-08-2012, 04:19 PM
chadx451 chadx451 is offline
99 Monte AC/heater problem
My 99 Monte Carlo LS has a problem with the ac and the heater being stuck in the defrost mode. The heater and the ac work fine but it won't switch to anything else. I heard this could be a vacuum prob. I found a hose that runs from the top of the upper intake manifold. It goes to a T then one end to the firewall and the broken end is by the battery. I don't know were the broken end goes!!! Is this the problem or something else? Any help would be great! Its the 3.1 (3100 sfi v6)
Old 07-08-2012, 06:33 PM
aleekat aleekat is online now
Re: 99 Monte AC/heater problem
Look under the battery area for a black canister shaped object. You may only see it from underneath.
Old 07-09-2012, 07:43 AM
brcidd's Avatar
brcidd brcidd is offline
The other end is in front of wheel well- behind splash guard- and terminates at plastic reservoir mounted there.....connect it-- battery gases have corroded that plastic line
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-09-2012, 04:52 PM
There was not anything there but thank anyway aleekat.
Old 07-09-2012, 04:58 PM
I think I got it brcidd thank you. Not sure what purpose it serves though. Any help with my other problem would be great. Can't figure out why the ac/heater won't switch to the vent.
Old 07-09-2012, 06:11 PM
Tech II Tech II is offline
That's called a vacuum tank....stores vacuum via a check valve to provide vac to your HVAC, when the vehicle accelerates(this causes loss of vac due to the throttle plate wide open).....
Next move is to check if you have vac going to the actuators....
Having ac/heater problems snoopy_03_13 Alero 8 03-08-2006 04:56 PM
AC/HEATER Problem ryinglin Grand AM 4 01-02-2006 10:04 AM
AC/Heater Problems whydidibuyaford Explorer | Explorer Sport Trac 0 09-19-2005 11:54 PM
2000 Stratus ES noise and ac/heater problems Immersion Stratus 2 12-26-2004 01:44 AM
93 grand am ac-heater problem bbbbbfb910 Grand AM 2 04-12-2004 12:34 PM
