Go Back   Automotive Forums Car Chat > Kia > Spectra | Cerato | Forte | Mentor
Spectra | Cerato | Forte | Mentor Couple 4 and 5 door models.
Old 07-07-2012, 12:50 PM
mxmissle mxmissle is offline
2001 Kia Spectra Turn signal problems
2001 Kia Spectra 1.8L A/C no sunroof. Turn signals don't come on at all. Tapping around the fuse box with a screw driver gets them to work fine, then they stop after a bit. I'm assuming "TNS" is the turn signals.
Should I replace the S/B fuse and the mini relay, or check the pin/connection tension first.
If I unbolt the under-the-hood fuse panel, am I walking into a complete rewiring job? Or does it hold together well?
I just don't want to create more problems than I have.
Thank you in advance.
Old 07-11-2012, 06:46 PM
rhandwor rhandwor is offline
Re: 2001 Kia Spectra Turn signal problems
I removed the fuse holder on my Sorento just disconnect the battery ground first. If you have a bad pin purchase an inline fuse holder at the parts store use the same size fuse. It may be corroded at the connection.
Old 07-12-2012, 06:43 PM
Thank you. I found an aftermarket flasher relay under the dash with "custom" wiring. I checked the relay by repeatedly tapping it with a screwdriver while it was flashing, then realized the positive wire wasn't crimped properly. Stripped off heat-shrink, chopped out connector, new connector and heat-shrink, flasher works fine. I also stumbled across a burned up fuse (10A) titled "ROOM" on the legend of under hood fuses. Replaced that, so I guess the "ROOM" has power now. I'm just stunned that i couldn't find a single repair manual for a KIA anywhere in Waco. I'll have to look around Houston.
Old 07-12-2012, 07:28 PM
I got a cd rom manual on ebay for my Sorento.
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 11:40 PM
Turn Signal Problem JSchlenk91 Century 5 03-13-2011 06:50 PM
2000 Kia Spectra fuel reset switch? fathairysmurf Spectra | Cerato | Forte | Mentor 0 03-07-2010 05:34 PM
Gauges stopped working on 2001 Kia Spectra 2001KiaSpectra Spectra | Cerato | Forte | Mentor 0 06-05-2008 05:29 PM
