Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-08-2008, 05:10 PM
JScottB JScottB is offline
98 SL A/C not cold anymore
What's the proper procedure for refilling the refrigerant in the AC and how can I tell if the pump is screwed up? I got to messing with some R134a even though the AC already worked (DUH) and now the AC wont put out any cold air. AC clutch is engaging and rad cooling fan turns on the sec the AC is turned on ..... basically everything is doing what it's supposed to be doing except putting out cold air.
Old 07-08-2008, 05:15 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: 98 SL A/C not cold anymore
You say you were messing with R134A when the A/C was working? Does that mean you filled it even though it didn't need it? You may have overcharged the system. You need to get a set of guages and measure the pressure in the system.
Old 07-08-2008, 05:26 PM
Yep, that's what I did . The can had a gauge with it and I kept it in the pressure range I was supposed to and it continued to work for about a week after but now it doesn't. I feel like an idiot already so please don't ask me why I did it, I just hope I don't have a major AC repair bill due to me trying to fix something that wasn't broke in the first place. Please excuse me while I find some corner to hide in.
Old 07-08-2008, 05:32 PM
Oh and just so you know, I used a partial can (near empty) of R134a that I had used on another car ....that did need it so don't think I dumped a full can of R134a in. None the less I still feel like an idiot.
Old 07-08-2008, 06:58 PM
RC1488 RC1488 is offline
............tisk tisk :P
What does the guage say the pressure is at now? Should be at "Normal" with the a/c on HIGH.
My honest suggestion....pay the money...have it discharged and then recharged as i have a feeling you let air into the system or over charged it.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 07-08-2008, 07:47 PM
Cat Fuzz Cat Fuzz is offline
A/C should really only be handled by properly trained people. Take it in and have it fixed.
Old 07-08-2008, 07:49 PM
Hungrycat7's Avatar
It would probably be beneficial to you to take the car to a shop. Just make sure they have the right equipment for the A/C. They will hook it up to a recycler that will drain the fluid, recycle it, check for leaks, and refill with new R134. Car is 10 years old so it certainly would not hurt to have done. Also I don't think most places will charge you a huge amount of money!
Old 07-08-2008, 08:27 PM
Gauge was reading 35lbs with AC on high after I got done "playing" with it. Taking it to someone who actually knows what they're doing with AC sounds like the plan.
