Old 07-06-2012, 09:32 PM
charliecosson charliecosson is offline
Question serging speedometer and tachometer
My 1999 Plymouth grand voyager SE 3.3liter engine has developed a tach and spee
dometer problem.At various times the tach will surge@ 200 rpm and at the same time the speedometer will top out and then they will return to where they should be.I can make this happen also bye driving in reverse,stopping and putting it in overdrive and the tach and speedometer will serge without the car ever moving.Anyone have an idea or know what's going on. I don't and could use some help.Thanks to all with an imput.Charlie
Old 07-07-2012, 02:13 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: serging speedometer and tachometer
First make sure your battery and connections are up to the task. These vans are sensitive to low erratic power. Second, try a cluster self test. Hold the trip and reset knobs in then turn the key to "on/run". After a few seconds the instruments and lights will start to cycle on their own. The speedo and tach will cycle to 4 readings then return to zero.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
charliecosson (07-07-2012)
Old 07-07-2012, 09:01 AM
Smile Re: serging speedometer and tachometer
Rip,Charlie here. Got your maybe fix that seems to have turned into a fix.Don't know yet,haven't taken it for a long test drive yet but the backup test proved to be a no problem here thing.Thanks a bunch Rip.
speedometer and tachometer not working pasha786 Cabrio 1 11-26-2007 02:57 PM
SPEEDOMETER & TACHOMETER QUIT molitorisrex Aerostar 0 12-12-2005 11:23 AM
Tachometer/Speedometer...and a few other things 96aurora Aurora 11 05-05-2005 04:06 PM
lexus gl300 speedometer and tachometer needle don't illuminate andrew111 GS300/GS400/GS430/Aristo 0 06-27-2004 10:28 PM
Speedometer and Tachometer problem gamezo Jetta/Vento/Bora 8 05-10-2004 12:28 PM
