Old 05-29-2010, 03:46 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
silverado problem stall and sometimes stops
Hey guys I have not posted here in a while Enjoying many miles with my silverado but now an issue has occured perhaps someone can guide me in the right direction ...when I start my truck and drive it after a few mins or so, the truck wants to stall and sometimes stop on me for some strange reason.... after a reset or several and i let the truck warm up a bit, the truck runs just fine....No Engine codes .. I replaced the Egr valve from a junk yard thinking that it might be the problem. however, the problem still exist... I called a gm tech and he said it could be a fuel pump problem any advice would be great keep in mine that this only happens after I let the truck sit for a while
Simon
Simon R
2001 Silverado W/T 4.3
124,000
Old 05-29-2010, 08:15 PM
j cAT j cAT is offline
Re: silverado problem stall and sometimes stops
Simon
since this occurs when cold/cool ONLY...I would suspect the ECT is out of range..when this occurs the computer will not command a rich mixture when cold..this is the result...also NO check engine CODES .....
It is possible that the fuel pump may be putting out a slightly below spec pressure...or other fuel componets/filter/reg...
since only cold start issue this is a good guess..also a cheap part ..
Old 05-31-2010, 10:30 AM
jbryant jbryant is offline
I just had a similar problem with my '98. Spent weeks trying to find the problem. Turns out it was the ENG-I fuse in the box under the hood. Although mine is a 5.7 I would assume that yours has the same fuse. Check that and other fuses.
Old 05-31-2010, 11:51 AM
gremlin96 gremlin96 is offline
is your 4.3 fuel injected or do you have a cap and rotor. if you have a cap and rotor replace them. the design of the cap causes arcing in side. since it does it cold i would say you have water in side and it arks. you will get no codes till the truck dang near stops running.
Old 06-02-2010, 08:20 PM
Checked that fuse ...looks good
Originally Posted by j cAT View Post
since this occurs when cold/cool ONLY...I would suspect the ECT is out of range..when this occurs the computer will not command a rich mixture when cold..this is the result...also NO check engine CODES ..... It is possible that the fuel pump may be putting out a slightly below spec pressure...or other fuel componets/filter/reg...
This seems very plausable... at one time I belive I did get an engine code for the ECT awhile ago but the truck was fine then and I didnt think much of it.... maybe its coming back to bite me in the ass but would I see it in idle??? the truck revs and seems to idle ok in park
I talkled to another silverado owner today and he belives it the fuel regulator ill have to check it and see
Simon R
124,000
Old 06-16-2010, 11:30 PM
Looks like I owe you a six pack man cause that was it!! The Ect was the problem... Good bit of info
Simon R
124,000
Old 06-17-2010, 09:03 AM
thanks for posting your results . this is a common issue with these vehicles//
I have saved much time and money using these forums ..
Old 07-04-2010, 12:09 PM
spackelman spackelman is offline
Does ECT = engine coolant temp sensor??
2002 Silverado 2500HD Crew Cab, Full Box
8.1
K & N Intake
Pioneer DEH960MP w/ Pheonix Gold Octane 5/4 Amp
Polk momo6500 Front Polk momo 650 Rear
Bulldog Auto Start
Old 07-04-2010, 01:03 PM
yes
Old 07-04-2010, 05:16 PM
yes
Thanks jc
8.1
K & N Intake
Bulldog Auto Start
