Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 07-05-2012, 08:45 PM
Sticks21 Sticks21 is offline
2000 Trans Am Engine Miss
Hello, I have a 2000 WS6 with 35k miles pulling DTC codes PO352 and PO354. I swapped the B coil pack with the A coil pack and it still pulls the same codes. When I clear the codes, they come back fairly quick. Lastly while driving the car is very sluggish and has a noticable miss and the headers for the #2 and #4 cylnders are fairly cool. Any thoughts as to what is causing the issue? Thank you!!
Old 07-06-2012, 08:00 AM
Tech II Tech II is offline
Re: 2000 Trans Am Engine Miss
Chances are those cylinders are not firing......those codes are for the circuit to each coil......have you checked spark output from the coil?
Have you checked the circuits to the coils on 2 and 4?
Old 07-06-2012, 08:08 AM
No I haven't......could you explain how I would check the circuits to the #2 and 4 coils? Would appreciate as much description as you are able to provide. Thank you!
Old 07-07-2012, 12:59 PM
Simple to check.....pull coil/module off of plug.....disable fuel.....install spark plug tester(some look like a spark plug with an alligator clip to ground it) to coil module....crank vehicle.....does it have spark? No? Swap with another coil/module that is firing.....still no spark?
If my schematic is right, "A" is black, that is a ground....."B" is a low reference ground to the PCM....."C" is the trigger signal to make the module fire.....and finally "D" is ignition voltage......So if you put a test light between "D" and "A" and "D and "B", and it lights in both cases, since you swapped a know good module previously, then you are not getting a trigger signal on "C" from the PCM.....
If that is the case, you have to check the circuit from the module to the PCM, if ok, you need a PCM....however, this is rare....my money is on a wiring problem......
Engine Miss? FordBoss88 Taurus | Taurus Wagon 1 08-23-2010 10:03 PM
2000 gt idle control/revving by itself wantaGTO Grand AM 2 11-19-2009 12:01 AM
1998 Trans Sport engine misses under load kawtool Trans Sport 3 10-18-2009 08:44 PM
rebuilt engine misses after 375 miles? rfb427 F-Body Problem Diagnosis 2 02-25-2009 08:25 AM
2000 Windstar Engine Miss mike1572 Windstar 0 11-29-2006 02:12 AM
Tags
engine , miss , ws6
