Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-06-2009, 09:23 PM
kawtool kawtool is offline
1998 Trans Sport engine misses under load
Recently I noticed the engine misses a beat when accelerating onto a highway or climbing hills. Usually only one beat. This was probably discussed earlier but could not find thread. I know there could be a lot of reasons. Changed the fuel filter, was dirty, but did not solve the problem. What should the next step or steps be? Ignition wires, plugs......?
It's has a 3400 cc motor with O/D. transmission and 320,000 Km. on it.
Mick
Old 10-06-2009, 10:23 PM
96tsport 96tsport is offline
Re: 1998 Trans Sport engine misses under load
If you don't know the history of the plugs/wires yes, good place to start. Any codes?
~70k last 3 years with no major issues ~270k total; unknown prior history.
Old 10-06-2009, 10:26 PM
Or you could pull the front plugs & see how they look, those ones are easy.
Old 10-18-2009, 08:44 PM
n4ujolarry n4ujolarry is offline
I cured a similar problem by getting rid of the heat shields around the spark plug boots. The wires were grounding spark at the heat shield. I tossed those pesky aluminum spark grabbers in the trash.
