Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-03-2012, 03:25 PM
Datnip Datnip is offline
2000 ranger ABS light is on
The lower bolt that holds the Pads and Caliper to the right front wheel
came loose fell out and got jammed under the rotor. This fractured my rim in six places but did not damage anything else. Even so I have replaced both rotors and pads. I got a replacement bolt from the junk yard off of a ranger they had and made sure both sides are tight so this can't happen again. But for some reason the ABS light is on. I have checked the wires on both sides and everything looks to be just fine. Anyone have any ideas? The ABS light was not on before this. Or does anyone have any idea how to find out what is triggering the ABS light?
Thanx for the help.
Old 07-03-2012, 04:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2000 ranger ABS light is on
Did you replace the rotor with the correct one? The ABS sensor ring is attatched to the rotor. If there is no ring for the sensor, will set a speed sensor code.
Old 07-03-2012, 07:14 PM
The ABS light was on before I replaced rotors. It came on when the bolt came off and fractured the rim. But the ABS ring your talking about is inside the wheel bearing hub. I had to replace the wheel hub a few years back because the ABS was kicking in when I was coming to stop no matter what the road conditions were.
I guess I will have to look things over all over again. This is so weird. Does anyone know if there is a device that would tell me the fault like the OBDII code readers?
Sorry, Yes I replaced with the correct Rotors. they are an exact copy of the old ones.
Old 07-05-2012, 04:27 PM
Well I finally got the ABS code from Advanced auto.
B1230 is the code which tells me that the ABS rear speed sensor
needs replacing. Once I get my truck back from front end alignment
and tires I will get one and see what happens.
I hope this helps anyone that might have this same issue.
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 08:51 AM
2000 Ranger 4x4 trouble with ABS engaging tjohn2401 Ranger | Courier 1 01-15-2010 10:05 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 07:40 AM
2001 ranger abs light rayno Ranger | Courier 7 08-11-2005 12:49 PM
1997 Ranger Abs Light dazedmc Ranger | Courier 2 04-21-2005 10:05 PM
