Old 07-03-2012, 01:48 PM
lbranham1101 lbranham1101 is offline
Exclamation temp sensor
well i found i had a pin hole in the bypass hose, fixed it, doesnt lose coolant anymore, but its still getting hot. before the thermostat went out months ago, the temp was always at the 1/4 mark. it always stayed there, til the thermostat went out. replaced it and ever since it loves to 220 mark.. well i flushed the rad twice. fixed the bypass hose, filled with coolant, all was well i thought... well it over heated again today. lil over 220. im thinking the CTS? (coolant temp sensor) but someone said there is actually 2. 1 that controls the gauge and 1 that goes to the ecm or .something? i got lost in his ramble... does anyone know about any of this? thanks
Old 07-03-2012, 02:05 PM
Tech II Tech II is offline
Re: temp sensor
This vehicle usually has two....single green wire to a sensor is for the gage....two wires(blk and yellow?) to the sensor for the ECM.....
You would need a scan tool to compare both sensors....
Sure you are not losing coolant that may be creating an air pocket? Cooling fan operating ok?
Old 07-03-2012, 02:09 PM
Re: temp sensor
no coolant loss.. its a 92 so how would i use a scanner on it? and do you know the location of these sensors?
Old 07-03-2012, 02:12 PM
thephantom1492 thephantom1492 is offline
Re: temp sensor
Also, take note that the engine love to run hot too.
It is possible that the engine is just running at it's normal temperature now.
1/4 sound to me that the thermostat was faulty and stuck open.
Old 09-10-2012, 05:27 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: temp sensor
its possible he had a 180-185 deg thermostat in there and put in a 195 like most auto stores sell. So it'll read higher on the gauge.
This model isnt as bad as the newest GA's when purging air from the cooling syst!
1999 Grand Am SS 3.4 OHV
Old 09-11-2012, 02:19 PM
Re: temp sensor
Update, car is fixed, after having 6 mechanics rack their brains
Come to find out, the metal line coming from the overflow tank
Was clogged.
Old 09-15-2012, 03:49 PM
Re: temp sensor
Sometimes its the simple things overlooked. Glad you got it solved !
p1492-battery temp. sensor wisneski Grand Cherokee | Grand Cherokee SRT8 0 10-30-2011 08:32 PM
2001 grand prix new coolant temp sensor problem wolfkin_j Grand Prix 4 08-07-2011 04:18 PM
4T60E transmission temp sensor clutch492 Grand Prix 8 12-02-2009 07:17 PM
94 s-10 blazer 4.3 w temp guage! exalteduser Problem Diagnosis 8 08-26-2009 04:54 PM
01 Silverado Coolant Temp Sensor wiring okieguy Silverado 1 08-10-2009 07:39 PM
