Old 08-06-2011, 09:42 PM
wolfkin_j wolfkin_j is offline
2001 grand prix new coolant temp sensor problem
The temperature gauge was recently misbehaving so I decided to change the engine coolant temperature sensor on my 01' grand prix 3800. With the old sensor it went a few days reading nothing on the temp guage even though I was driving my car all day, it did this for two days. then all of a sudden it jumped to normal and started jumping up and down from cold to normal as I was driving. After i took it out and installed the new one it now reads the temperature in the red and im stumped... Anyone out there know whats going on?
Old 08-07-2011, 01:14 AM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
Re: 2001 grand prix new coolant temp sensor problem
nope. probably a problem with the gauge itself. we spent near 500 bucks tryin to figure out why mine was doin it.. we gave up and i drove it for 4 years like that. i never actually had any over heating problems. the gauge was just goofy
2000 Grand Prix GTP Daytona: 4k original miles
1997 Pontiac Grand Prix GTP bought with 68k, sold with 112,000, and i loved every mile
2011 Subaru Legacy 2.5i (daily driver)
1973 MGB
Old 08-07-2011, 09:26 AM
procaddytech procaddytech is offline
With the sensor unplugged and key in run the gauge should read it's lowest reading. With the connector jumped the gauge should peg hot. Even more precisely the sensor is 1,365ohms at 100 degrees F, and 44ohms at 280 degrees F. Are the terminals that plug into the sensor spread and creating intermittent contact? That would cause a jumpy gauge.
Old 08-07-2011, 03:38 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Did you use any teflon tape on the threads?
The sensor uses the threads as a grounding point for it, if you don't have a good contact you can have that kind of problems.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-07-2011, 04:18 PM
It would be best if you could monitor coolant temp. in the PCM data list with a scan tool and compare it to the reading on the cluster gauge. Did you replace a 2 wire sensor with black and yellow wires or a single wire sensor with a green wire?
2001 Grand prix gt coolant fan stays on all the time roman1978 Grand Prix 3 11-06-2007 06:46 AM
1998 Jimmy coolant temp sensor problem Chris Fields Problem Diagnosis 8 01-09-2007 02:52 PM
OBDII Code P1296, new coolant temp sensor right? YZ125rider21 Golf 1 08-25-2005 09:50 PM
coolant temp sensor problem crxsirpr '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-15-2005 12:59 AM
2000 Grand Prix GTP coolant temperature sensor julie21078 Grand Prix 4 02-22-2005 06:30 PM
Tags
coolant , guage , sensor , temp , temperature
