Go Back   Automotive Forums Car Chat > Toyota > Highlander/Highlander Hybrid/Kluger
Old 07-03-2012, 12:21 PM
tjgalvez tjgalvez is offline
2009 4 cyl transmission dip stick
Where can I locate the trans dip stick. I searched all around, can't find it. 2009 4 cyl base highlander, thanks.
Old 07-12-2012, 10:54 AM
typesix typesix is offline
Re: 2009 4 cyl transmission dip stick
Some newer cars do not have a dipstick to check tranny fluid level. If you have owner's manual, it should tell you if there is one, in engine compartment diagram.
The Following User Says Thank You to typesix For This Useful Post:
tjgalvez (07-12-2012)
Old 12-20-2012, 09:53 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
If there is not a dipstick right next to the battery on the engine side (black handle) then there is none due to the world standard fluid that is checked via drain plug on the transmission pan and scan tool
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
explorer transmission dip stick tube replacment teepster Explorer | Explorer Sport Trac 0 08-13-2007 08:14 AM
rust on the transmission dip stick adamantsssssssssss Blazer 2 11-22-2005 02:00 PM
transmission dip stick f carillo Grand AM 1 10-25-2005 08:07 AM
96 sunfire gt transmission dip stick ja1son1 General Discussions 1 07-13-2004 01:16 PM
Transmission Dip Stick hrpoolgirl21 Grand AM 2 11-13-2003 03:30 PM
