Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-01-2012, 10:00 PM
Joe Bough Joe Bough is offline
2004 Tohoe daylight running lights
The bulbs on my 2004 Tohoe keep burning out. Sockets look burnt. I replace the bulbs about every 90 days. I need help!!!
Old 07-02-2012, 08:23 AM
j cAT j cAT is offline
Re: 2004 Tohoe daylight running lights
buy the LL type bulbs. LL is long life.
use some silicone grease on the bulb contact pins. make sure the socket conections are clean. if the socket is damaged from heat go to a scrap yard for replacements. then use the silicone grease on the contact pins to prevent future socket issues.
Old 07-04-2012, 02:10 PM
bass_caster bass_caster is offline
i replaced mine several times as well and got fed up. i ended up getting the led equivelent bulbs and havent had to replace since. im going on 8 years or so with them. im not sure what makes them burn out but i had the same issue with the fog lights on my '00. maybe it was heat, moisture, or maybe vibration, but they all kept burning out regularly. when i installed the led bulbs i did apply some elect grease in the sockets and i havent replaced a bulb since.
2004 Suburban Trailer Running Lights BlackForest Suburban 2 04-07-2010 10:34 PM
daylight running lights? hywman TrailBlazer | Trailblazer EXT 7 09-10-2004 07:22 PM
daylight running lights spryst Lumina 4 12-26-2003 02:51 AM
Tahoe with no daylight running lights sgt.rock C/K 1 12-14-2003 09:35 AM
Daylight Running Lights off when turn signal on FirstJimmy Jimmy 1 10-24-2003 04:53 PM
