Old 06-29-2012, 08:38 PM
ajb0009 ajb0009 is offline
Rear heat and A/C not switching
I have a 98 Windstar with 3.8L that has rear heat and A/C. Every year at the change of seasons (spring and fall) it takes a few tries to get it to switch over. This year, no matter what I do, it just keeps blowing heat in the back instead of A/C, regardless of where any of the dials are turned to. Any idea where the door is or what ever causes either hot or cold air to come out? Anyone else ever had this problem? Thank you.
Old 06-30-2012, 09:00 AM
kevink1955 kevink1955 is offline
Re: Rear heat and A/C not switching
I had the same problem with my 96, turned out to be the switch in the front console that controls the rear A/C. It's not only an electrical switch but it switches the vcccunm to the rear unit.
Untill I replaced the switch after checking that i had vac on 1 of the lines I hooked the vac lines together and the rear unit switched to the upper vents and A/C.
The switch is easy to replace and is avaiable from most online supplyers
The Following User Says Thank You to kevink1955 For This Useful Post:
ajb0009 (07-01-2012)
Old 07-03-2012, 08:51 PM
tacomabobd tacomabobd is offline
Send a message via Yahoo to tacomabobd
I had the same problem on my 96, it too was the temp control up front.
Bob
The Following User Says Thank You to tacomabobd For This Useful Post:
ajb0009 (07-09-2012)
Old 07-15-2012, 03:16 PM
Thanks again, the switch took care of it. I bought it from the local dealer. Ford part number F68Z-19986-AA, Motorcraft part number YH-1465, paid $38.70, $40.84 with tax. Took fifteen minutes to install; works great now. Thank you.
Rear Heat and A/C fan control not working jvwindstar01 Windstar 1 07-16-2007 11:44 AM
1995 sunfire--2.2...no heat and speedo is not working...HMMM?? deepee8686 Cavalier Problem Diagnosis 0 02-09-2007 07:45 PM
01 Burb, Rear Heat/AC Blows but not hot or cold? Bluesky4x4 Suburban 1 03-17-2006 10:14 AM
rear heat and ac control not working garync1 Windstar 5 06-19-2005 10:56 AM
Rear Window and Keyless access not working nevr2late 4Runner/GX470 0 05-16-2005 01:18 PM
