Go Back   Automotive Forums Car Chat > Saturn > Aura
Old 06-29-2012, 08:02 PM
rmullennix rmullennix is offline
2008 Aura - Drivers Power Seat
2008 Saturn Aura - XE - 3.5L - Seat just stopped working. Could not find a fuse in the engine compartment nor on the center console fuse blocks. Which fuse is for the seat?
Old 06-30-2012, 08:19 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2008 Aura - Drivers Power Seat
Look for the DRV SEAT 30A fuse in the rear compartment fuse box. In the trunk, behind L/R wheel area.
Old 06-30-2012, 11:58 AM
Thanks, found the fuse, replaced, and it promptly blew again. Cannot keep doing that at $5 / ea. Any thoughts on why the seat is blowing the fuses? I do not have the equipment to troubleshoot (multimeter, amp clamp, etc...) All the connectors on the seat are in place, the seat operates with a 40A fuse; which tells me the seat motors are operational. The fuse blew when the seat was "bottomed" out against a hard stop.
Old 06-30-2012, 02:13 PM
gmtech1's Avatar
You either have a shorted wire,shorted switch, or the seat motor is pulling too much amperage. Be careful with installing oversized fuses as you may find the problem by way of a fire. Could smoke an entire harness or give you a very hot seat. Unplug each motor, one at a time, and see if the fuse blows, unplug the seat module and see if it blows.
Remove Drivers Power Seat- 93 Regal bluefox111 Regal 2 10-09-2010 09:54 AM
Power Seat Failure panteli2011 Thunderbird 2 07-23-2009 05:33 PM
2002 Windstar Driver Power Seat Problem DavidChen Windstar 5 06-26-2005 05:47 AM
Driver power seat is awful kevrbrown5 G35 Sedan 5 01-09-2005 07:49 PM
1993 Park Ave driver Power seat Dvmoore00 Park Avenue 0 01-09-2005 01:13 PM
