Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-25-2012, 01:00 PM
comet240 comet240 is offline
01 3.8 harmonic knock sensor removal
hi i like to know is the sensor right at the end of the starter the knock sensor when u laying on ground and its the one straight up? and is on one wire?
and the other knock sensor where is that exactly? do you have to lower engine or something?
and whats the purpose of 2 knock sensors backup?
Old 06-25-2012, 02:13 PM
Re: 01 3.8 knock sensor removal
sorry topic shluldnt say harmonic as i was copying the title from my other post
Old 06-26-2012, 08:21 AM
maxwedge maxwedge is offline
A990 racer
Re: 01 3.8 harmonic knock sensor removal
2 banks, 2 knock sensors.
Old 06-26-2012, 08:25 AM
ya i know that i just wanted to know if the sensor is the one right at the end of the starter and wehre the other one is? and why do you need 2 knock sensors?
Old 06-26-2012, 09:53 AM
A990 racer
Piston noises can occur on both banks. Yes that should be it.
Old 06-26-2012, 12:13 PM
ok thank you and do you know why this engine has 2? i remember my 91 z34 only has one and a bad spot in beween transmision and oil pan
is the 2nd one for backup if the first fails?
Old 06-26-2012, 07:02 PM
A990 racer
I guess I am not making myself clear, there are 2 banks in this engine thus a set of pistons on each bank most or all obd11 engine have one sensor or 2 under the intake, or one on each side of the block to detect detonation/ engine rattling on either side of the engine.
Old 06-26-2012, 10:13 PM
ya i knew you said it has 2 and i was asking why comparing it to the luminas engine where its magnetic and if it breaks it falls in teh engine but only has 1 i was just curious why it uses 2 as opposed to one,
least this one here it unscrews where other one is a bolt and u gotta drop the engine to replace the knock sensor
Flashback II; Deja Vu? 3 Pony Cars in One! ZoomZoomMX-5 Completed Projects / Gallery 14 07-07-2012 01:07 PM
01 3.8 harmonic balancer removal comet240 Impala | Impala SS 8 06-27-2012 08:52 PM
