Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-24-2012, 05:54 PM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
03 Explorer Coolant Loss and Smell but No Leak
I have an 03 Explorer with the 4.0 engine. There is a strong smell of coolant and the reservoir does go down slightly once a week or so. There is No Leak whatsoever that I see, I have checked under the hood, under the vehicle, under the dash, everywhere...nothing. Where is the coolant going? This seems to be a common problem, I work at a quick lube and almost all of these explorers are low on coolant when they come in.
Old 05-06-2013, 10:05 PM
plymouthcranbrook plymouthcranbrook is offline
Re: 03 Explorer Coolant Loss and Smell but No Leak
Head gasket leak?
Old 05-06-2013, 10:24 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Is the smell from the engine compartment or the exhaust? If from the engine compartment, and the leak is not noticeable, it's probably not a head gasket but rather a small hose or seal leak that is allowing a small amount of coolant to drip on something hot and burn off before it hits the ground. If the smell is from the exhaust, then head gasket or cracked head could certainly be the issue. A cylinder leakdown test would help identify that.
-Rod
2000 3.5L Coolant loss and misfire steffenk Intrigue 5 05-11-2010 01:26 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 01:19 PM
'97 3.0 Vulcan 172k: Coolant Loss and #1 Plug Connection? Colt Hero Taurus | Taurus Wagon 3 08-20-2009 04:23 PM
coolant loss and oil level rising wigs2469 Silverado 1 06-28-2009 03:40 AM
Coolant Loss and engine shudder when starting dphess Altima 15 05-16-2007 08:29 AM
