Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-24-2012, 09:15 AM
primal1 primal1 is offline
99 tahoe with no fuel
i'm not getting fuel to the fuel rail. when i turn the key the the relay clicks, but not giving voltage the the gray wire. so i bypassed the relay, and the fuel pump still won't kick in. pulled the tank, checked ground. its good. is there some kind of feed back loop telling it not to feed fuel that i can't find.
Old 06-24-2012, 10:45 AM
j cAT j cAT is offline
Re: 99 tahoe with no fuel
if you jumped out the fuel pump controling voltage devices , applied 12volts to the pump feed and no pressure then the pump in n/g.
could be if this was a hacked pump install when the OEM pump failed that the splicing done to acept the OEM wiring was poorly done.
use delphi pumps If the pump is airtex then this is also the reason it is not working.
if you run the vehicle with fuel below 1/4 mark this is quite common.
replace filter every 30-40,ooomi
Old 06-24-2012, 10:58 AM
777stickman 777stickman is offline
Check and/or replace the ECM B fuse in the Underhood Fuse box.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 10:09 AM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 10:58 PM
2002 Tahoe acts like it's out of gas with fuel left in tank gugno1 Tahoe 1 05-16-2007 10:54 PM
02 Tahoe wont start with fuel under 1/4 tank bradenix Tahoe 2 04-16-2005 05:06 AM
