Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 06-23-2012, 10:55 PM
DOUGLASNC DOUGLASNC is offline
tRANSMISSION IS ACTING UP AFTER ERASING CODES
Replaced EGR gasket after trying to clean valve (EGR FLOW CODES) and erased codes.Short test drive and all seemed good so my daughter took it on home.Shortly she called saying the trans started acting as if it didn't want to stay in gear and would stop moving in gear.Could I have messed something up while removing the EGR valve, or erasing the codes? All was running fine when she left for home... Oh ,it;s a 99 Silhouette... Thanks for any advise..
Old 06-24-2012, 10:36 AM
Re: tRANSMISSION IS ACTING UP AFTER ERASING CODES
ok, checked codes and TPS code was on...un-pluged harness and pluged it back ,erased code and all was good again...May need to replace TPS or check for loose harness wire..
2005 Grand Caravan Transmission Problem - No limp - No fault codes aricsdaddy Caravan | Voyager 10 01-07-2012 05:43 PM
O2 Sensor and Trans codes...also some interesting behavior after an oil change. beach87 Lumina 0 05-24-2010 04:35 AM
2002 Transmission Codes P700 and P740 rjs0421 2nd Gen 00-05 0 08-04-2009 09:28 AM
Transmission acting up skarloey Grand Prix 25 11-13-2004 09:09 PM
Disconnecting battery to erase codes? hunter01 Blazer 1 10-21-2004 12:54 PM
