Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-23-2012, 08:39 PM
97explorersport 97explorersport is offline
plug replacement 0n 99 i30 Infinity
I think I may heve mad a mistake. When I replaced my plugs I coated the plug and the receptor with Dilectric.....now it appears that they my be arcking in the tubes. Looks like I am going to pull the plugs/Coils and wash them down and reinstall them this time using some boot seal......or maybe nothing...... Suggestions
Old 06-24-2012, 05:04 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: plug replacement 0n 99 i30 Infinity
Electrons dont jump through di-electric grease as it works as insulator - this grease allows electrons pass via a metallic contacts having few molecule thickness (of di-grease) between theses contact points... Most common greases have in fact di-electric properties. Main function is to keep the corroding oxygen out. (Oxygen in the air is the main culprit 'ruining' the contact surfaces)
Some info http://www.cardomain.com/ride/748507...maxima/page-14
Whatever, clean your coilpacks as the grease there is not necessary. It is mainly an insulator, also blocking heat transfer = n.g.
Note that coilpacks 'die by the mile', only replacement helps after they start failing...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Trying to replace my spark plug wires and plugs Metal_King Windstar 26 02-22-2007 07:10 AM
1992 325I Air filter replacement and spark plug replacement rdog28 3 Series 4 07-13-2003 04:47 PM
spark plug replacement changedagame108 Engineering/ Technical 3 02-27-2002 06:49 AM
