Old 06-23-2012, 03:15 PM
Dano 00TA Dano 00TA is offline
Tranny problem/question...electrical maybe?
Having a problem with my 00 4x4 5.3 silverado tranny, after driving it for a while today all of a sudden it wouldn't shift into 2nd and was slipping real bad, then lost all gears....no drive/reverse at all, but if I shut it off start it back up then it went into gear. It did this a few times while I was waiting for a tow, would lose all gears then would be ok after restarting it, but still slipped. Then after letting it sit waiting for the flatbed I started it and it shifted fine with no slipping. Sounds to me like a electrcal issue but wanted to check here to get some opinions. Thanks
Old 06-23-2012, 05:40 PM
j cAT j cAT is offline
Re: Tranny problem/question...electrical maybe?
have a transmission shop read drive train GM codes, and check pressures/internal debris.
my guess the sun shell is cracked. this is a common failure.
if the shell is damaged get a new/rebuilt torque converter also a 1year warrantee. tell them to replace the solenids and a system fluid line flush.
The Following User Says Thank You to j cAT For This Useful Post:
Dano 00TA (06-25-2012)
Old 06-23-2012, 07:38 PM
Actually, it was rebuilt about 2yrs ago because the sunshell cracked. I'd say it has no more than 15k on the tranny now, so I'm hoping it's not too bad, and I did have a ''beast'' shell put in. It's gonna go on a scanner Mon morning to see what's up.
Old 06-24-2012, 09:38 AM
if the transmission fluid system / radiator cooling fluid/ torque converter was not properly cleaned/replaced then this is gonna happen with the failure you had 2 years ago. this is quite common when things are not properly done.
Dano 00TA (06-26-2012)
Old 06-25-2012, 07:50 AM
transman618 transman618 is offline
If you have lost all gears and you have slipping then the sun shell is not the problem. Its also not likely an electrical issue since reverse is involved. With 15k on the rebuilt I would have a trans shop check the line pressures. I'm betting its something in the pump. How is the fluid level?? What does the fluid look like?? Smell like??
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
The Following User Says Thank You to transman618 For This Useful Post:
Old 06-25-2012, 10:09 AM
transman
It's at the shop now and I should be getting a call sometime today. As far as fluid the level, look and smell were all ok. Wasn't even thinking about the pump being the culprit....only reason I was thinking electrical was even when I'd lose all gears or it'd slip if I shut the truck off and start it then it'd go into all gears, and right before the flatbed got there to tow it, I took it for a little drive and it seemed fine? No slipping and it shifted fine. I hate tranny problems
Old 06-25-2012, 11:48 AM
Yea, thats classic symptoms. The reason why I asked about the fluid level and condition is if the fluid is real dirty then there is a chance that the filter is stopped up. Sometimes when a filter is stopped up there will be trash blocking it while the engine is running and when you shut off the engine the trans pump also shuts down and some of the trash in the filter will drop back down into the pan which will basically partially unplug the filter. When you start the engine again the trans will be able to get hydraulic pressure for a short time before it becomes stopped up again and the trans neutrals. Let me know what the trans shop says. I still think its a hydraulic issue.
transman
Old 06-25-2012, 12:14 PM
Unfortunatly big bucks also Thanks though for the help!
Old 06-25-2012, 02:15 PM
what is the report of the transmissions failure ?
With 15,ooomi on a transmission repair, I would like to know the reason for failure.
Others , with this type failure after a rebuild , it is usually the repair company using cheap parts and not properly cleaning the contamination up.
cost for a proper repair with the sunshell failure should be around $2500................also it comes with follow up checks and the warrantee .
Old 06-25-2012, 02:26 PM
Still no word yet about the problem. Will let you know when I find anything out. The rebuild was 1300+ (can't remember exactly) and I did get a 1yr/10000 mile warranty which of course is expired.
Old 06-25-2012, 06:17 PM
1300.oo for that sun shell replacement is for sure a low ball price. they must have done a cheapo job.
thanks for any info on whats going on with this. many will find all this useful.
Old 06-27-2012, 10:17 AM
Well, just got the bad news. Mech drove it this morning and said it was fine for a bit but then started shifting real hard in 1-2/2-3 then pulled the pan to find alot of metal shavings Quoted between 2g 2300 for a rebuild. I've replaced trannys in cars quite a few times but never did a 4x4 truck before, how much is involved in a r&r and is it even possible w/o the use of a lift? Just trying to save some bucks here.
Old 06-27-2012, 10:58 AM
if the vehicle is in good condition , has below 150,ooomi I would have a good tranny repair shop rebuild it and have them do the follow up checks and most importantly the back up warrantte which should be 2 years and 30,ooomi ..
the norm is 2500 for this repair. the whole fluid system must be cleaned and a new/rebuilt torque converter to avoid another failure.
you cheaped out the first time 1300 and now you back to this issue again. do you thing it will change if you try to repeat ?
the other option would be scrap yard tranny. then sell vehicle.
still though that fluid system will need a good cleaning. metal in the pan sounds like a sun shell failure , though could be other things. rapid failure like that is the sun shell most times. now that mess needs cleaning and that takes time and effort until done correctly.
Old 06-27-2012, 11:55 AM
Well, bit the bullet and told him to do it. The truck is in very good shape and has 104k miles on it, so it's worth keeping. He said 2300 was a worse case and might be a couple hundred cheaper. I will post exactly what he finds when he digs into it.
Old 06-27-2012, 12:10 PM
I would tell the rebuilder that you intend on keeping the vehicle for a few years and if he believes parts need replacing to call you for your approval. explain that you want it all done correctly for a reliable repair.
vehicle forum members have regretted buying 2007 and newer vehicles. the new vehicles are with more issues. also they have struts springs which do not offer the suspension support, that your vehicle has .
post back how it all worked out. also what was the failure component .
99 Pontiac Montana Tranny problems? wilson8260 Montana/Montana SV6 9 12-22-2009 09:16 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 03:41 PM
95 4x4 tranny problems / questions Mechanicapped Blazer 3 03-15-2006 09:14 AM
Tranny problems? Or Electrical Lotus49 Camaro Discussions 11 09-18-2004 09:03 AM
