Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-22-2012, 07:22 AM
samchev29 samchev29 is offline
please help im stumped...
ok i love my 01 impala 3400 i think . i have 239000 on car almost everything removable is changed motor 112000 trans 134000 car is running extremely hot but not overheating no leaks causing trans fluid to burn i have changed 3 times this month will shift funny slip jerk change fluid its good again first time shot tcc code trans heats up too check engine light will come on car will slip or pop out of gear on hard take off or if moving will keep kicking like in and out of od trans will act up till cool reconnect battery good to go again cat is clogged im 85 percent sure some dumbass that i bought from had a tiny aftermarket put on what should i do i have 5000 dollars in this car im ready to junk it i cant take it anymore any advice will be hepful would the cat cause trans problems or should i think transmission its very weird it goes away comes back next day new fluid its like new
Old 06-22-2012, 01:23 PM
danielsatur danielsatur is offline
Re: please help im stumped...
The hydrostatic Transmission needs a constant hydraulic pressure to do the shifting that needs to be done, if the deliverability of engine isn't there, it could make the Transmission look bad.
1) Check your coolant fans.
2) Coolant pressure test.
3) Coolant bleed procedure.
4) Do a back pressure test on both catalytic converters.
Old 06-22-2012, 01:30 PM
Whats the proper bleeding procedure
Old 06-22-2012, 01:56 PM
I would recommend www.alldata.com , there might be a little screw on your thermostat housing.
Doe's your Heat work on high max?
Is there any shortage of coolant?
Does your coolant fans turn on when your HVAC is on cool max?
Do you have any bugs, or road litter in front of your radiator + air cond condenser?
You might consider a coolant flush + back flush on your heater core, new thermostat, because of age + mileage.
Old 06-22-2012, 01:59 PM
Originally Posted by danielsatur View Post
i would recommend www.alldata.com
doe's your heat on high max work?
Does your coolant fans turn on when your hvac is on cool max?
heat works ac ice cold fans seem to work
Please help, stumped. ctwright Sentra | 200SX (USDM FWD) 5 04-07-2009 06:17 AM
my Suzuki Swift wont start and my mechanic is stumped! can someone please help me! Rngcnty Metro 4 09-30-2006 09:18 AM
Please Help Stumped On This One jas7865 S-10 10 10-19-2005 11:08 AM
please help. everyone here is stumped littlekebb05 323/Protegé/Familia/Etude/Allegro 17 08-01-2004 05:15 AM
Please read, i really need help. Stumped.... 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-30-2004 08:01 AM
Tags
hot , lacks , power , running
