Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-20-2012, 08:06 PM
vintshave vintshave is offline
COMPLETELY stuck lower caliper pin on 93 Caprice
Help me before I go insane...please!
I have a 1993 Chevy Caprice Classic. I am working on changing the pads on my front brakes. One side completed successfully. On the other, I was able to remove the top caliper bolt (The bolt is removed with a 3/8 Allen bit and socket wrench) but the bottom one is stuck.
How stuck?
Here is what I tried so far...
-Used the bit with a socket wrench (no dice)
-Held in the socket wrench while hitting the end with a hammer (no love)
-Soaked the area in PB overnight (nada)
-Used a breaker bar with the bit (ended up stripping the inside of the bolt)
-Hammered the area of the caliper where the bolt is frozen (aside from removing dirt, it's still in there)
-Heated the bolt-threads with a blow torch, then tried a Vise Grip on the outside (stripped the outside of the bolt)
I'm not sure what else there is to do and I am desperately looking for ideas. One thought I had was to use a sidecut saw to slice through the pin in a couple of areas to get it off.
DO you think that is the best approach? Any other ideas? I MUST get this off!
Thanks in advance!
Old 06-20-2012, 09:50 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: COMPLETELY stuck lower caliper pin on 93 Caprice
I had something like this happen once, years ago. You already know you have to replace the bolt, so ... what I did was use a large pair of ChannelLocks on the outside of the bolt to break it loose. You should be able to get ample purchase on the bolt with ChannelLocks ... a hint would be to clean the bolt head with brake cleaner, first, so that there's no penetrating oil left over from the attempt at loosening it before, else your tool will slip.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-21-2012, 12:00 AM
Will those behave any different than the Vise Grips? All the Vise Grips did was to strip the bolt.
Old 06-21-2012, 12:42 AM
silicon212's Avatar
Confoundingly Lucid
With the long handled ChannelLocks, you can get more grip on the bolt. Remember to eliminate all sources of potential lubricant from the bolt.
Old 06-21-2012, 09:48 AM
Are channellocks better than vise grips? I ended up stripping the bolt with Vise Grips.
Old 06-21-2012, 11:45 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Channellocks or Vice grips, if they are old and the serrated teeth on the jaws are worn, they won't be able to bite into the bolt enough to get a good grip and not slip. If you look at new vice grips and channel locks, the serrated teeth on the jaws have nice sharp edges to give a good bite.
You could also try a small pipe wrench if space allows.
just my , good luck.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 06-22-2012, 06:24 PM
j cAT j cAT is offline
use a 8 inch pipe wrench . If needed a pipe about a foot long. to get the added torque which maybe required.
I would just go to the scrap yard with the old one in hand, and get one off a vehicle for cheap.
the used caliper maybe cheaper than buying a new pin.
Old 06-23-2012, 07:39 PM
Blue Bowtie's Avatar
Registered Offender
Chan-Nel-Lock makes pliers. Vise-Grip (formerly Peterson) makes welding clamps. Vice grips have soft jaws. Try a Chan-Nel-Lock 410G if (when) your Vise-Grip slips.
I would use heat on the threaded area of the caliper first, than apply a good penetrating fluid (NOT WD-40) as it cools to allow the fluid to wick into the threads. Try not to heat the caliper to the point where the fluid cup exceeds 300°F or you will be rebuilding the caliper completely.
Old 06-27-2012, 04:39 PM
96capricemgr 96capricemgr is offline
Couple weeks ago I had a similarly hopelessly stuck bolt.
Used MAPP gas to get it cherry red and quenched it with Liquid Wrench a few times. Liquid wrench is not my first choice but afterwards when I tried to get the vise grips on it I found the bolt spun out by hand.
I really need to get some more Kroil or at least PB Blaster, the Liquid Wrench is OLD because it is the one I use least, better than WD-40 but not as good as the others.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
sticky rear caliper pin causing squeal? surferfletch Rodeo | Passport | MU 4 01-16-2006 06:28 PM
Breaking Caliper Pins kissfan007 Lumina 2 10-06-2005 09:08 PM
Caliper Pins kissfan007 Lumina 2 08-11-2005 09:16 PM
help 90 caliper Pin Bolt veghead Mighty Max 0 02-12-2005 07:32 PM
Removing Caliper Pins 96Thunderbird IndyFord187 Thunderbird 1 09-09-2004 06:41 PM
Tags
brakes , caliper , caprice
