Old 06-20-2012, 05:54 PM
Steemus Steemus is offline
Question Intermittent Problem Starting 2000 Grand Voyager
Hi. I’m having am intermittent problem with my 2000 Plymouth Grand Voyager, and so far have not been able to find a mechanic who can help. Occasionally (usually after having sat for two days or more without having been driven) the van won’t start. The starter and battery are not likely the problem, as the car turns over, but it just won’t “catch”, almost as if there is no fuel getting to the engine. After doing nothing with the van but letting it sit for several hours, it starts right up. Has anyone else had this problem? Any ideas or suggestions? The mechanics say they can’t diagnose or fix the problem, because it’s sporadic and (obviously) not happening when I bring the van in. I would greatly appreciate anyone’s help with this. Thanks very much!
Old 06-23-2012, 03:13 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Intermittent Problem Starting 2000 Grand Voyager
Connect a fuel pressure gauge and check the fuel pump pressure while cranking. Should see 49 psi.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-23-2012, 09:03 AM
Thank you so much. I will do this.
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 05:56 PM
starting problems on 93 grand voyager dmtm817 Caravan | Voyager 12 06-03-2006 06:11 PM
Intermintent starting problem 98' Plymouth Grand Voyager klrmb Caravan | Voyager 4 10-09-2005 05:47 AM
2000 grand voyager white smoke at startup and alot of questions I have, pls help me dealseaker Caravan | Voyager 7 05-14-2005 01:43 PM
2000 Grand voyager SE Electronic? sauramon Caravan | Voyager 1 05-14-2004 07:28 AM
