Old 06-19-2012, 09:39 PM
Tonyr's Avatar
Tonyr Tonyr is offline
08 IAC valve
Does anyone have a picture showing where the IAC valve is located on a 2008 GP Base model? Thank you.
Old 06-20-2012, 07:18 PM
rickisrad rickisrad is offline
Re: 08 IAC valve
There is no IAC valve on our generation due to the electronic throttle body. there is an Intake air temperature sensor located inside the MAF.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
IAC valve ??? ray1 Camry/Camry Hybrid/Vista 3 04-02-2004 07:49 PM
IAC valve help almxdupintegra Integra 2 03-31-2004 05:44 AM
sohc v-tec IAC valve ? mellowboy Engineering/ Technical 4 07-20-2002 03:24 AM
Anyone have an IAC valve from their old D series? FLAWLESS Engineering/ Technical 3 04-22-2002 08:12 AM
NEED: IAC valve from a D series engine FLAWLESS '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-17-2002 11:38 AM
