Old 06-19-2012, 01:04 AM
dagan06 dagan06 is offline
finding TDC
Does anyone have any tips on finding TDC on my 2003?
Old 06-19-2012, 02:42 AM
phillipshaw phillipshaw is offline
Re: finding TDC
Same question with him!. Hope someone could help us here.
“In three words I can sum up everything I've learned about life: it goes on.”
― Robert Frost
Old 06-19-2012, 08:08 AM
Tech II Tech II is offline
Re: finding TDC
OK, this is the 2.2 Ecotec engine....timing is not adjustable......so my question is why do you want to find TDC?
Have you pulled the front engine cover, and have replaced some of the components(timing chain, tensioner, etc.) and are trying to time the engine? If you are, get a manual because it is a little involved and you only have one shot at setting it.....
What kind of problems or symptoms do you have?
Old 06-19-2012, 08:28 AM
Re: finding TDC
I have to change the timing chain, gears, ect. I have a manual but it is very vague about finding TDC.
Old 06-19-2012, 09:30 PM
Re: finding TDC
Ok, I looked at the other posts, and see this is the engine with the ticking sound from the timing cover area......should have just continued with the same post.....
The ecotec engine replaced the quad 4.......I liked timing the quad 4 engine better, because you can recheck the timing after two manual cranks of the engine.....pins line up in the cams and you have the timing mark for the crank sprocket....
Ecotec is not like that......there are three marks(different colors) on that chain that correspond to marks on the two cams and the sprocket....if you rotate the engine twice, those 3 marks do not line up again to recheck your work....so you only have on shot at this........
Been awhile since I timed one.....is this a GM manual or a generic one? If I remember right, the two marks that are the same color, go on the cams and the different colored mark goes on the crank....should be a mark on the crank sprocket and on the block(around 5 or 6 o'clock).....start the chain with the mark on the crank and work your way back around with the chain counter clockwise, aligning the other two marks on the chain with the marks on the top of each cam.....if the alignment marks on the cams are on the bottom, then the engine is 180 out of timing.....that's why BEFORE I take the chain off, I have already manually rotated the engine approximately in the timed position.....
Like I said in the other post, there was a new kit for this.....2 cam sprockets, crank sprocket, chain, tensioner, and a new oil nozzle with a larger opening.....makes sure the tensioner is retracted correctly, and that you use the proper procedure to expand it....
Old 06-20-2012, 12:09 PM
danielsatur danielsatur is offline
Re: finding TDC
Use a heavy duty paper wad on cylinder 1, and turn her over until she pop's.
What is the easiest way to find TDC Escalus Cutlass Series 1 03-28-2006 04:26 AM
finding tdc S13Slide Taurus | Taurus Wagon 0 03-27-2006 02:23 PM
Need to find TDC, Please help ? gschretter C/K 2 04-05-2004 09:48 PM
Poor man's way to find TDC confutatis Taurus | Taurus Wagon 1 02-06-2004 10:54 PM
