Old 06-18-2012, 10:45 AM
mrwizzard mrwizzard is offline
Steering doesn't center after turn with new struts
I got new struts installed and seems the steering does not center after left/right turns but will stop about 5 deg to the center.
I have taken it back to the shop and they say since it is new it must be broken in and would take about a week.
Does this make sense or is there something else wrong/not installed properly?
it also makes creaking sounds on right turns too. i heard this is normal as well.
I don't want to go back and tell them they are wrong and look like an idiot but it doesn't feel right to me and i don't want to go on a long trip if it is dangerous.
Thanks!
Old 06-18-2012, 11:25 AM
maxwedge maxwedge is offline
A990 racer
Re: Steering doesn't center after turn with new struts
BS, when doing struts you must do alignment. no break in!! The noise could be anything, strut bearings, tie rod ends, needs checking.
Old 06-18-2012, 01:58 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Agree with Max. If it steers ok, but the steering wheel is off center, they either did not align the vehicle, or just failed to get the wheel staight when they set the toe. If it's binding, and noisy like you say, the strut mounts/bearings are most likley to blame. These cars were horrible for the creaking noises on turns or bumps. It's caused by metal to metal contact in the mount/bearing assy's.
As Max said, no break-in required, thats a croc.
Steering wheel shakes after new struts Oopey Camry/Camry Hybrid/Vista 2 08-03-2009 02:00 PM
94 S-10 blazer that doesn't start after a new fuel pump was install Bakerytech Blazer 11 02-26-2005 12:53 PM
