Old 06-16-2012, 07:24 PM
Denisthemenace Denisthemenace is offline
Accord1990EX-R number 2 cylinder not working
Hi,it's not working at all,like completely dead number 2 cylinder,when I take the wire off nothing changes.
Changed wires,new sparkplugs,there is spark,thought may be injector,put injector from other cylinder,same thing. Lot's of air coming from valve cover oil cap when I open it,is it normal?
No compression test yet. Oil looks ok,there is no antifreeze in it.
Any suggestions?
Thank you.
Denis R
Old 06-16-2012, 07:31 PM
danielsatur danielsatur is offline
Re: Accord1990EX-R number 2 cylinder not working
Did you roll the spark plug + plug wire to another cylinder?
Still need to do a compression test on cylinder 1.
If compression is bad, a smoke test can pinpoint if it's on a Intake or exhaust valve.
@ TDC on 1, if smoke is coming from the Intake, or Tail pipe.
Old 06-17-2012, 03:44 AM
It's completely new set of wires and spark plugs,nothing wrong with firing order. Why roll to another cylinder?
Didn't do any compression test yet on any cylinder,don't have compression tester yet.
thnks.
Old 06-17-2012, 10:40 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
If you have a lotta blow-by through the oil fill cap and see a wet plug in that cylinder, chances are good it holed a piston.
A vacuum gauge reading will show you any catastrophic compression loss in that hole. Needle will drop out every time that one comes into an intake cycle...needle will shake so hard at idle you'll hear it rattling in the gauge. If so, you got big trouble.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
Denisthemenace (06-17-2012)
Old 06-17-2012, 10:44 AM
You can kind of do this by the seat of your pants without a gauge...of course it's not real specific, but if you pull a vac line and put your thumb over it, and run the motor, and allow just enough air to sneak by your thumb, you can feel the loss of vacuum in the dead hole....the hose will actually "buzz" to the fast pressure changes, instead of a steady draw like a healthy engine pulls.
Even with a dead hole from ignition or fuel problem, vacuum level is not greatly affected. That hole is still pulling air in. If it's not, you got internal breakage, holed piston, swallowed a valve, something....
...empty gun rack.
Old 06-17-2012, 11:38 PM
You scaring me,I don't want to deal with the piston....
thanks for answers any way.
The spurk plug is dry.I just run it for awhile took it out it's dry.Is it guaranty that piston is ok? Also I notice slight tinkling sound this time,not sure where is it coming from,but I imagine it could be valve or broken spring bouncing around. What do you think?
thanks.
all the best
Denis R
Old 06-18-2012, 03:49 AM
Well that's better....yeah if you'd holed a piston you'd have all hella oil on that plug.
Interesting that plug should be wet fouled with fuel if that hole is dead.
Let it cool down, restart and see if the exhaust runner from that cylinder stays cold as the others warm up. Sounds like it may be running, just very weak.
It's not just missing at idle, is it? If it seems to overcome it as rpms rise, you could be dealing with a catastrophic vacuum leak here too...bad intake gasket, cracked intake runner, etc.
let's see. You swapped injectors and no change, you verified the miss didn't just move to the other cylinder after the swap I'm sure....pretty easy to pull that valve cover and watch the followers operate the valves while it runs...see if you got a dead valve or a broken follower or something...
...empty gun rack.
Old 06-18-2012, 03:51 AM
PS EGR passage doesn't open to the #2 intake runner on this one does it? I can't remember...but that could explain some things too....
...empty gun rack.
Old 06-21-2012, 05:46 PM
taking head off,compression 0 in it, others 175 steady,springs looks ok under valve cover everything moves.
Old 06-23-2012, 04:23 PM
My Head:
Old 06-23-2012, 10:06 PM
Oh shit. Is that a chunk missing outta that right intake valve's edge, or just a trick of the light?
Where did all the oil come from?
Not good....
...empty gun rack.
Old 06-25-2012, 02:41 AM
Not good....
The oil from wet test,and this chunk is exhaust valve chunk.
Old 06-29-2012, 01:19 PM
what is tightening torque for rocker arm camshaft assembly,any one please?
I found the pattern,but not torque: http://www.justanswer.com/honda/1kto...cyclinder.html
thnks
all the best!
Denis R
97 Breaks not working crackedvenom Taurus | Taurus Wagon 1 05-12-2010 09:17 PM
cylinder #5 not working. Can i Drive? skemoto Camry/Camry Hybrid/Vista 4 04-05-2010 09:39 AM
New power break booster and cylinder are not working. . .need help juno Grand Cherokee | Grand Cherokee SRT8 2 11-17-2007 05:13 PM
1995 Maxima number 5 cylinder not firing ecrumb Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 05-19-2006 01:15 AM
