Old 06-13-2012, 08:33 PM
AlphaCrow AlphaCrow is offline
Engine vibration making catalytic rattle
Hey all. Figured out my catalytic is rattling, though not from inside, but the heatshield part. Seems when I turn my A/C on when the engine is cold, that is usually enough to make it rattle. Sometimes it just rattles no matter what. What is the best solution? Motor mounts? Put a bracket brace on the exhaust pipe somewhere? Tack weld the heat shield onto the catalytic better? Thanks
Old 06-13-2012, 10:07 PM
FishFind FishFind is offline
One Hot Shot
Re: Engine vibration making catalytic rattle
check the rubber mounts that hold the exhaust in place.
Old 06-14-2012, 01:15 AM
aleekat aleekat is online now
Have you banged against the shield with engine cold? Had gravel trapped between heat shield and cat on mine.
Old 06-16-2012, 07:33 PM
I'll check, but it's pretty clean under there. Seems to be the motor itself causes enough vibration to rattle the pipes, and cause the noise on the cat. I'll need to look at the rubber mounts (thanks, didn't even think of that). Also wondering if I need to change out the muffler gasket to the exhaust pipe. It's kinda rotted. Drips water, though I suspect that's due to the 100% humidity here.
Old 06-24-2012, 11:55 PM
Solved it: where the rubber mounts attach to the frame, the bolts were missing, and that weird, weird brace for the exhaust was rattling on the frame. Got some M8 bolts and reattached to frame with loc-tite Thanks for tips everyone
Engine vibrates in Drive at stop lights makes me nots bigal6030 Camry/Camry Hybrid/Vista 10 01-23-2009 11:42 AM
'05 Tacoma - Vibrating Noise (Wind Rattle?) lzmann Tacoma 0 03-30-2007 08:18 AM
S10 shaking and making a rattling noise when parked Ducaire S-10 4 08-02-2005 09:52 PM
corolla 96 making a rattling noise when accelerating hard hungt1999 Corolla/Matrix/Voltz 2 08-31-2004 11:55 PM
HELP! My Z24 makes a rattling noise AaronAlbZ24 Cavalier 4 04-12-2004 01:40 PM
