Old 06-12-2012, 07:00 PM
frfghtr141 frfghtr141 is offline
Unhappy 98 Bravada oil leaking from drivers side of engine.
I have a 98 bravada that is leaking oil from drivers side of engine just above ujoints on front driveshaft... pours out on start then stops... does again on stop.. cannot figure out what is there to cause. cant find anything in chiltons to show it.
Old 06-13-2012, 07:00 AM
Tech II Tech II is offline
Re: 98 Bravada oil leaking from drivers side of engine.
Is this coming from the oil cooling lines that go to the radiator?
Old 06-14-2012, 09:18 PM
old_master's Avatar
Advisor/Moderator
Ya won't find anything, that you can trust, in a Chiltons manual I agree with Tech II, probably the oil lines or the gaskets between the adapter and the block.
http://shop.advanceautoparts.com/web...RPGASKAMS_____
You have to know how it works,
to figure out why it doesn't.
2001 water leak on drivers side floor ksierens Aurora 9 08-28-2008 09:58 AM
95 LeSabre Oil leak on pass side above oil filter... AJsOffroad LeSabre 2 06-02-2008 06:48 AM
Liquid Leaking from Driver side Header xPolish660x C/K 4 05-04-2005 12:42 AM
fast oil leak from rear of engine (not seal) rbade Cutlass Series 0 06-12-2004 10:24 PM
Transmission fluid from driver side leaking? bird2003 Corolla/Matrix/Voltz 3 10-18-2003 12:26 AM
