Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-12-2004, 10:24 PM
rbade rbade is offline
Question fast oil leak from rear of engine (not seal)
Fixed start problem. Now, I also replaced the intake manifold gasket set and the little gasket on top of the oil pan area. Started the car and I have an oil leak draining off the engine at the back above the oil pan. I used a flashlight and determined that it isn't coming from the old distributor plug. Any suggestions on where it may be leaking. I cleaned the area around the rear engine seal and it doesn't appear to be coming from there. It is a rather rapid drip coming from there and I want to fix it before the car gets road use.
