Old 06-12-2012, 08:53 AM
RyanD RyanD is offline
Brake Problem need help today please
On My way into work this morning in stop and go traffic my brakes lost all thier pressure, after pumping the brake real quick a couple times my truck mustered up enough to get me into work. I just checked on it and saw that like i thought there was brake fluid leaking. The inside of my right rear tire is covered in fluid and i myself have never worked on drum brakes, on top of that im not willing to drive it home today after work with a brake fluid leak, does anyone have any ideas as to what may be leaking in my brake so i can get it done this afternoon. any help is appreciated
Old 06-13-2012, 09:02 AM
j cAT j cAT is offline
Re: Brake Problem need help today please
welcome to the autoforum. normally giving details of what vehicle we are having issues with helps. however in your case this is just the typical GM brake line defect. these brake lines rust out . I have had 2 failures myself even with periodic inspections.
the other item could be the brake cylinder of that wheel . the brake drum maybe too worn /too lagre now and with the shoes worn cause the brake cylinder to blow out.
when a brake line blows you will have no brakes. if you know what your doing you could crimp the defective line and then have some braking as well as reduce the fluid leaking until repairs can be made.
so have your vehicle checked for these brake issues whenever you do your oil changes and lube .
The Following User Says Thank You to j cAT For This Useful Post:
RyanD (06-13-2012)
I need help today...please!!! stefy1066 Grand Cherokee | Grand Cherokee SRT8 1 09-24-2008 12:36 PM
Brake Problem- Need Help Kat03Tib Corolla/Matrix/Voltz 2 10-13-2004 08:25 PM
Monster Motor Problem, Need Help Immediately!!! Please. wheel1856 Engineering/ Technical 0 06-27-2004 10:40 AM
Monster Engine Problem, need help immediately!!!! please wheel1856 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 06-27-2004 10:38 AM
Need help today please...Turbo prep and/or NA prep clatescivicr '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 01-25-2002 09:02 AM
