Old 06-10-2012, 06:06 PM
tonytog tonytog is offline
Smile 98 voyager Where is the leak ??
Have a 98 voyager, the A/C from time to time has need to be charged and would last a good while. well not any more. 20 0z can leaked out in less the 1 day. time to fix the leak. Where is the most common area for these to leake from? Compressor clutch evaparator coil etc. Would love to hear wher anyone has found them.
Old 06-10-2012, 09:40 PM
DeltaP DeltaP is offline
Re: 98 voyager Where is the leak ??
On a '98 I'd say anywhere. Although the compressor front seal is pretty common on any vehicle of that vintage. Need to have it leak tested. You may have more than one leak.
Old 08-05-2012, 08:45 PM
Spit Spit is offline
My guess would be the evaporator. The evaporators on these vans are notorious for leaking... I have a 97 and it was the cause of my AC leaks. It's a big job, have to pull the entire dash out to do it. Dealer would want $1500 or more. You should look for any oil leaks on all of the AC lines and connections. Check the condenser for leaks the same way. If you have rear air on your van you will have 2 condensers, check both of them. If you don't see leaks in these easy to check places...I would expect it it the evap.
Spit
Old 08-05-2012, 09:26 PM
danielsatur danielsatur is offline
I would save the $ from air cond service & drive it the other 3-months of year.
2000 grand voyager, Where to get internal trim parts mareswj Caravan | Voyager 1 10-17-2008 03:27 PM
91 voyager where is the Oirl Sensor comet240 Caravan | Voyager 0 05-12-2008 09:10 AM
2001 voyager/where is the fuel filter majee Caravan | Voyager 1 07-06-2007 10:25 PM
Oil leaking from where the exaust valve connects to the head!! bmoreboy52 Eclipse Problem Diagnosis 4 11-12-2004 08:40 PM
