Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-08-2004, 03:18 PM
bmoreboy52 bmoreboy52 is offline
Send a message via AIM to bmoreboy52
Oil leaking from where the exaust valve connects to the head!!
OK i need help bc there is oil leaking from where the exuast valve connects to the head. and oil is gettin all over the place and idk what i should do to fix it!! So can nebody help me out on this and tell me what i need to do to fix it??
Old 11-08-2004, 03:26 PM
Re: Oil leaking from where the exaust valve connects to the head!!
Can Someone Please Help Me Out??
Old 11-10-2004, 02:23 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Where exactly is the leak? Exhaust valve?
Kris
2012 Genesis Coupe 2.0t
Old 11-12-2004, 09:34 AM
buzzin buzzin is offline
Re: Re: Oil leaking from where the exaust valve connects to the head!!
sounds to me like ya got oil seal problems or more, you can try to replace the oil seal if it doesn't work head need to be removed for
inspection. this sound right to u guys!
Old 11-12-2004, 08:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
NEed a better description. One sign of oil getting by the seals is oil leaking down the valve stem, you can see it looking at the valve stem through the intake or exhaust ports. Sometimes its just the seals, sometimes the guides are bad and new seals wont last a couple days. Best bet is to have a machinist check it over. Most machinists hate changing guides, so dont worry about them saying its bad just to get another ~150 bucks
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
