Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 06-09-2012, 09:47 PM
theungreatone theungreatone is offline
2003 Monte Carlo SS check engine light flashing Pleas Help!
Hi. My 2003 MC SS has been acting up, the check engine light starts flashing at me and the car starts shaking when I turn the AC/Heat on. I have no idea what is going on. I know nothing about cars and before I take this to a mechanic, could someone tell me what might be the issue, I do not want to go somewhere and get totally ripped off.
Thanks
Old 06-09-2012, 10:18 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2003 Monte Carlo SS check engine light flashing Pleas Help!
There is probably a misfire code set, could be a general code, or a cylinder specific code. May be caused by several things. Plugs, wires, coil(s), ect...,with the a/c on, its adding a load and making it worse. Need to have the codes checked.
Old 06-10-2012, 06:41 PM
My friend just ran the codes and we got some cruise control codes and a solid misfire on the 5th cylinder but he has no idea what it is. Do you have any ideas for me?
Old 06-11-2012, 10:00 AM
gmtech1's Avatar
Not sure on the cruise codes. With the #5 misfire, could have a bad plug, wire, coil, or even a burned valve in the head (least likley, but possible). Start with the plugs. espically if they have not been replace in a while, you can even swap plug and/or wire to another cylinder and see if the misfire moves. If its been awhile since the pluge and wires were replaced, I would just do that and see what happens.
1995 vw golf 2.0 check engine light SUCIO805 Golf 0 09-29-2011 09:43 AM
Check Engine Light Reset? papavonschoen Cougar 4 04-11-2011 02:10 PM
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
