Old 06-09-2012, 06:35 PM
mega8man's Avatar
mega8man mega8man is offline
1996 sunfire 2.4L shifting problem 3rd to 4th gear
My sunfire is not shifting from 3rd to 4th gear. I will shift fine all the way up to 3rd and then ir revs like it is in neutral when i hit about 43 mph. it gets a little bit of a jump if i get off the gas all the way and then back on it and i can get it up to 55 but the rpm's are at 4.5. I read a few different posts that seemed like they may have had the same problem but they werent describing the way my car is acting. I went and got the fluid exchanged today and also changed the throttle position sensor on a whim because someone told me it could be the problem. Oh and if you couldn't have guessed by the post it is an automatic.
Any ideas or test i could do would be greatly appreciated. Thank you!
Old 06-09-2012, 08:08 PM
Tech II Tech II is offline
Re: 1996 sunfire 2.4L shifting problem 3rd to 4th gear
Were there any codes, like shift solenoids?
What was the condition of the old fluid? Did they find any metal in the pan?
Certainly sounds like an internal problem.......
Old 06-14-2012, 08:16 PM
mega8man's Avatar
Alright! I'm sorry it took me so long to reply. I have been working on getting my code reader to work since the port was a little screwed up on the car and i couldn't pull the codes. But now i have the codes. hah too bad i still dont know anything about transmissions.. well the codes i pulled were:
P0753 Shift Solenoid A Electrical
P0758 Shift Solenoid B Electrical
P1810 Manufacturer Controlled Transmission
P0113 IAT sensor 1 High Input
When I had the transmission fluid changed there were no metal shavings in the pan.
Old 06-15-2012, 06:30 AM
mega8man's Avatar
Does anyone know how difficult it is to diagnose the shift solenoids? I wouldnt know where to start or how to test them.
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
'96 Sunfire 2.4L, Auto tran. Is this a problem worth fixing? cheryle96 General Discussions 4 04-07-2006 08:57 AM
2002 sunfire 2.4L a/c compressor problem Sunfire24 General Discussions 1 06-25-2005 02:56 PM
2.4L acceleration problems 2000 sunfire little john Cavalier Problem Diagnosis 4 03-29-2005 07:16 PM
EXTREMELY WERID PROBLEM, car shuts off at high RPM's in 3rd-4th gear FourG63 98GST Off-Topic 3 09-15-2004 02:50 AM
