Old 06-03-2003, 09:53 PM
99silverGT 99silverGT is offline
Send a message via Yahoo to 99silverGT
heater/ac controls
my 99 grand prix gt started about a week ago...........when you turn the a/c or vent on any setting including the defrost it blows out of all the vents. it is like the defrost, heat, a/c, and everything is on at the same time and it doesnt blow very hard. i think it might be the control panel, because the knobs dont seem to be locking in any specific setting. anyone else had this problem? let me know
Old 06-04-2003, 08:21 AM
ipec ipec is offline
The selector for heater, vent, defroster, or other settings, simply changes where the air blows out. There is a valve (kind of a way to think about it) in the dash that either closes, or opens, and routes the air to where it should be going according to the selector knob. This valve, or switch of sorts, will get stuck in any particular position sometimes on a variety of GM cars. Usually, the first symptom is that you start to lose fan speeds. Like you may have fan speeds 3,4,&5; but 1 & 2 don't work. Then you either lose other fan speeds, or then lose the defrost, or the ability to get air to your windshield. I believe I have heard of it locking while being completely open before, so that could be what's happening with you. It does have to be taken to professionals, but it doesn't cost much to have it fixed. $50-$130????
-IPEC for life
Old 06-04-2003, 08:40 AM
'00' GTP '00' GTP is offline
I used to have a S-15, and had that same problem. the issue was caused by a vaccum leak. I would check all of your vaccume hoses to see if there was one that was unhooked
just my $.02
2000 Black 4 Door GTP
3.4" pully
FWI
14.5 stock
2003 Red Accord Coupe
V6 6-speed
car-stats.com saies it runs 14.7
Old 06-04-2003, 08:45 AM
If it doesn't blow like it should even on fan speed 5, then it most definitely could be a vacuum issue (to back up that theory).
-IPEC for life
Old 06-07-2003, 08:47 AM
the switch apearantly was stuck in defrost. i put the knob back on defrost and pushed in kinda hard and turned it and i can get it to work right that way, so im pretty sure it is the control panel. i think the selector knob is stripped out. thanks for the help. if u lose speeds and it only works on one or two speeds that is the blower resistor module. i had to replace it about a year ago
Old 06-11-2003, 05:43 PM
Thanks for that tidbit. Glad to hear you found a resolution.
-IPEC for life
regular heater/ac controls to dual climate controls yourpappy Grand Prix 2 10-30-2007 06:40 AM
Heater/AC Control Switch "Issues" 98 Intrigue GL rowle1jt Intrigue 3 10-19-2005 08:44 AM
Need heater/AC controls before winter Ziggymidget5 Prelude 0 08-26-2004 05:54 PM
WTB: heater/ac controller ASAP.... honeybabes Cavalier 3 01-11-2004 02:57 AM
Heater/AC Control Panel goesman LeSabre 3 10-30-2003 08:27 PM
