Old 06-07-2012, 12:47 AM
fubard's Avatar
fubard fubard is offline
Air conditioning problem
Hello all, I have a 2000 Taurus SE with a 3.0L motor and 125Km. Last year I had the AC charged up and it's been working fine or so I thought. What I've noticed is that the compressor seems to always be engaged regardless of the control setting. If I select off it does disengage.It has manual climate control. I know that the AC system will cycle randomly but in my case it stays on. I was thinking it could be a problem with the unit that controls the random function of the AC or maybe a bad function switch. Has anyone had this problem and resolved it?
Thanks
Autos fixed with help from this forum:
1991 Chev Lumina auto engine hurled
1990 Ford Taurus auto death by high mileage
1995 Ford Taurus auto sold !!!
1989 Ford SHO 5 spd, sold, too finicky
1991 Geo Metro 5spd, SOLD, still ran great
2000 Chev Metro auto sold , mileage was poor
1998 Firefly 3 cyl 53mg!! SOLD I don't commute now
1993 Mercedes 300E sold...looking for a newer one
1999 Mercedes ML320
2000 Taurus my wife's new ride. Bought with only 105K
It's almost a fleet !!
Old 06-07-2012, 06:59 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Air conditioning problem
The way the climate control is set up does activate the A/C compressor for just about every setting. There are only a couple that do not call for A/C. Per the wiring diagram, power is routed to the A/C compressor clutch for all settings EXCEPT Off, Vent, and Floor.
-Rod
Old 06-07-2012, 10:47 AM
fubard's Avatar
Thanks for the reply,Rod. Late last nite I managed to find a PDF file for the wiring diagrams of the various AC systems. It does show the switch allowing the AC compressor to have power in all but a couple settings. I'll try to use those settings when I don't want the AC to run but it just doesn't seem right. Doesn't it waste fuel and cause more wear on the compressor? I may consider installing a switch to disable the AC relay.Even a temp sensor would work. If the temp gets too low then disable the compressor, except for defrost.
1999 Mercedes ML320
Old 06-07-2012, 08:37 PM
shorod's Avatar
SHO No Mo
It will cause the fuel economy to suffer a bit, but I'm not sure on the wear. Yeah, the compressor will be running more, but it will also be circulating the refrigerant which carries the oil, so it will be keeping seals and the compressor lubricated better as well.
-Rod
Old 06-08-2012, 12:50 AM
fubard's Avatar
-Rod
I'll check my owners manual.I thought the AC was cycled randomly to circulate everything since if the switch was left in a non AC mode it'd never circulate.
1999 Mercedes ML320
Old 06-08-2012, 06:04 AM
phillipshaw phillipshaw is offline
how long is this? May be you need to change it to new?
“In three words I can sum up everything I've learned about life: it goes on.”
― Robert Frost
Old 08-17-2012, 09:07 AM
jnc852 jnc852 is offline
Have you fixed this? I have the exact same problem on my '00 taurus SE. I have been pulling the relay in the fuse box to shut the ac off in the winter, but I'd really like to fix it. I dont have a schematic to see how its supposed to work, but checking the selector switch, it appears to work properly.
j
Old 08-17-2012, 09:45 AM
shorod's Avatar
SHO No Mo
The compressor SHOULD run in the winter to remove the moisture from the air and minimize the chance of the windshield frosting up.
-Rod
Old 08-17-2012, 11:16 AM
i know it *should* work for defrost, but I'd rather it didnt if it meant I had my AC clutch constantly engaged in the winter.
I tracked down an old schematic (not sure if its correct for my car) and it seems to me I might have a problem with the CCRM (constant control relay module). I'll have to have a closer peak when I find some spare time.
j
Old 08-17-2014, 10:35 PM
BeaJean BeaJean is offline
I have a Ford Taurus SES 2000, and it sat for a while about a couple of months, and before it sat, the air conditioning worked great, and it was so cold. After I got my license to drive I started it and the ABS lights came on and the air conditioner would not work, I went a whole summer without it. I finally found out that the part that was needed was right beside the air filter compartment. It was the mass air flow sensor that needed to be changed out, I changed it and it works just fine now.
Old 08-17-2014, 11:05 PM
shorod's Avatar
SHO No Mo
The mass air flow sensor should have no effect on the A/C working or not. It also won't effect the ABS. Are you certain the MAF is what you changed? Did you do anything else at the same time (such as install a new battery)?
-Rod
206 Air Conditioning Carl.I 206 2 09-18-2014 02:19 PM
96 grand voyager no air conditioning question proserver Caravan | Voyager 5 08-21-2011 01:45 PM
2003 Alero quits with air conditioning Stefphelps Alero 3 04-29-2009 07:16 AM
Air conditioning recharge Sentax '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-24-2009 10:25 PM
