Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 06-03-2012, 06:30 PM
bcopeland bcopeland is offline
1982 Monte Carlo 267 engine
I am trying to get this car street ready and need some help. The engine has a 2 bbl carb and a 3 inch throat on the carb. Question - can I fit a modern air cleaner on it? Any suggestions?
Old 06-03-2012, 07:24 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 1982 Monte Carlo 267 engine
What do you mean by " a modern air cleaner " ? Are you talking about a chrome dress up type of air cleaner or ....what ? If you want a stock type air cleaner , you'll likely have to go to a salvage yard and see if they have or can get you one ? Ebay is another good option for a stock one though likely not cheap ?
" Sometimes I grow so tired "
Old 06-03-2012, 08:47 PM
Thanks for your response! You are right. I meant a "dressed up" chrome air cleaner. I was wondering if I can buy one with a 3 inch neck that would accept the vacuum hose from the intake.
Old 06-03-2012, 10:47 PM
oldblu65's Avatar
The first place I would check is www.opgi.com ! They have many Monte Carlo parts , not sure about the entire air cleaner assembly though ? I know they do have replacement air cleaner tops in chrome so that might be a possibility ? If not , do a Google search for " 1982 Monte Carlo 2 barrel carburetor chrome air cleaners " and see what links come up ? The above mentioned website also offers a free catalog for your year and model MC , just have to fill out the order form . Good luck !
Old 06-16-2012, 09:27 PM
Thanks for all of your responses. I have another question. Can anyone identify what this part is and where it connects? its from that same 267 CI engine on the 1982 Monte Carlo.
Old 06-16-2012, 09:36 PM
oldblu65's Avatar
Which part are you referring to ? The black hose or the loose wire ? My guess is the wire likely goes to your engine temperature sender - may be wrong ? The hose appears to be a hose coming from the pcv valve - again , may be wrong ?
Old 06-17-2012, 05:27 PM
Sir, you are all on it! Yes, the wire. It is just hanging on the intake manifold and I was wondering where it hooked up into. I am trying to get the 267 running so I can try and make it an everyday driver. As for the hose, it seems to have vacuum.
95 monte carlo Z34 engine swap? barryz28 Monte Carlo 3 02-07-2009 08:01 PM
2000 Monte Carlo SS Engine Mounts MKet Monte Carlo 0 01-26-2005 09:00 PM
2001 Monte Carlo Check Engine Light Petey_J Monte Carlo 2 08-24-2003 12:44 PM
99 MOnte Carlo elect. engine fan test murphturph Monte Carlo 4 07-20-2003 06:09 PM
