Old 06-02-2012, 10:46 PM
Jaycinade Jaycinade is offline
Question engine swap
would i be able to swap my 95 Grand Am 3.1 v6 with a 3.8 supercharged Grand Prix GT? would there be lots of moding to the mounts? if so what year Grand Prix GT should i be looking for?
Old 06-03-2012, 07:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: engine swap
NO! The engine would probably fit but there are too many other issues that you would need to deal with. You would need a new transmission, axle shafts, fuel lines and fuel pump, PCM, new wiring harness and a host of other items too numerous to mention. Your best bet would be to purchase a used GTP somewhere. It would be much cheaper.
Old 06-03-2012, 05:38 PM
thephantom1492 thephantom1492 is offline
Re: engine swap
Also, take note that you can'T just change the PCM, as it is tied to the BCM.
The ABS is also tied to the BCM, so is the cluster in some case.
The radio is also tied to the BCM...
In short, the engine need the proper PCM for it, so does the transmission. The PCM need the matched BCM, and basically all of the rest of the electronics rely on the BCM. So you would need to change ALL the electronics module. Since the wiring is non-standard, you also need to change it all, or at best hack it up badly.
Then you have all the mechanics stuff... The transmission need the proper engine, so you also need to change the transmission. The axles match the transmission. The wheel hubs match the axles, the knuckle match the hub, and so on...
There is also driveability issues that could happend even if you succede to do the swap. The body is made for a certain engine weight and power... The suspension is tuned for the weight and gravity center. The brakes matched for the car weight and also to the weight proportion on front/rear...
Sure, lots of those issues are negligeables, but the electronics and mechanicals one are worrysome.
Old 06-04-2012, 06:19 AM
Re: engine swap
Ty for your input.. Now to find out how to get 3in1 taillights to fit on my car..
engine swap 85 engine into 88 truck spuds704 S-10 0 02-09-2010 10:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
swapping 91 wrangler 4.0 for 97 cherokee 4.0 - fuel lines mismatch rykowalspt Wrangler 1 03-26-2009 05:07 PM
Engine Swap or Tranny Swap???????? tempfixit Caravan | Voyager 4 03-15-2009 06:53 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
