Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 06-02-2012, 06:36 PM
FishFind FishFind is offline
One Hot Shot
Whats the problem?
Ok today I took my 1998 chevy blazer 4dr 4wd in to get a alignment. The first shop took it and tried and then told me they can't do it because I need new upper control arm bushings.
The second place I took it to told me they can't do it because it needs
-new pitman arm
-new idler arm
-upper/lower ball joints.
Both shops told me they could do the alignment but it would be a waste of money.
So what is wrong here? Why two different opinions?
Old 06-02-2012, 09:27 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Whats the problem?
-new pitman arm
-new idler arm
The first answer might be they're both telling you the truth and your vehicle needs all the parts they mentioned ! Or they both might be just trying to run your costs up for a bigger profit to their business ? Since your Blazer is a '98 model and ( unless you know it's entire history ) may have been abused off road at some time in the past which would accelerate the wear & tear on the mentioned parts especially if all the parts are original to the truck . I'd suggest trying to get a personal recommendation from a close friend who have had good service from an alignment shop . Good luck !
" Sometimes I grow so tired "
The Following User Says Thank You to oldblu65 For This Useful Post:
FishFind (06-02-2012)
The 350 is back and running great! Heres what the problem was.. bhw33191 Caprice 2 06-21-2010 06:28 PM
found what the problem was the hard way Helixrider Sportage 2 12-06-2006 11:15 AM
whats the problem with the 2.8 hotwheelsgt S-10 1 07-18-2004 04:20 PM
Whats the problem? GCguy2169 Car Audio 1 04-06-2004 08:58 PM
ECU or Wiring Harness problemI need to figure out what the problem is here. First a jdmteg98 Integra 3 06-02-2002 12:29 AM
