Old 04-06-2004, 08:26 PM
GCguy2169 GCguy2169 is offline
Send a message via AIM to GCguy2169
Whats the problem?
Ok im trying to hokk up 1 ten inch subwoofer with a amp in my girlfriends car. She didnt want to change the factory radio, so ok, I bought a Line output converter. Ok hook it all up, power, ground, remote, speaker, good connections, no sound? Whats is the problem?
btw...what should i hook the remote wire to? Her car has the monsoon sound system in it so it has the amps already in the back to power her componets, so i hooked the remote wire to it (spliced) ans it works when it wants to, so can anyone tell me a dependable place to put a remote wire, instead of hooking it to the hot wire?
Old 04-06-2004, 08:58 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Whats the problem?
Sounds like you attached the remote wire to the speaker signal, that's why it's "working when it wants to", you're trying to turn on your amp with an AC voltage = not gunna work.
Get a voltmeter and find out which wire on the stock amps is live when the stereo is on and dead when the stereo is off, then use that one as your remote wire.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
