Old 05-30-2012, 05:34 PM
327chevy 327chevy is offline
08 Silverado...... switched power source?
I need to find a switched power source to power up a back up camera monitor for my truck,preferably in the interior fuse panel or an easy location.Can someone point me in the right direction here?
Plus I need a place to isolate the wireless sending unit from weather as it's not waterproof;where would be the best place to locate this?Or what could I use for a "bag" or some such thing that is waterproof and commercially available?
Old 05-31-2012, 07:17 PM
j cAT j cAT is offline
Re: 08 Silverado...... switched power source?
withthe ignition OFF check for NO voltage at a fuse. 15amp sized. radio fuse should be a good source. tap that fuse input and use the camera fuse for the device , like your camera.
with the fuse pulled you will then find what side is the input.
mount the wireless antenna inside , near a window, it should work.
the camera fuse should installed at the fuse .
Best Way to add Power to my 04 Silverado WV_UNDERGROUND Silverado 1 03-17-2012 08:44 AM
Accessories Not Getting Power!!!!! Redneckboy360360 Silverado 8 01-18-2010 06:56 AM
Power source for clutch switch fixitornot Escort 2 06-04-2009 03:25 AM
2004 Silverado Satellite Radio Power Source pintola Silverado 3 01-02-2006 11:12 AM
