Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-30-2012, 05:08 AM
Major Funbags Major Funbags is offline
97 monte 3.1 stumbles upon acceleration
The car takes off from a stop as it should. However, it shifts hard from 2nd to 3rd gear and that's when it stumbles and doesn't want to accelerate. It'll go if you press pedal at least halfway down. It runs great other than that. It only has 60k.
Old 05-30-2012, 09:19 AM
Tech II Tech II is offline
Re: 97 monte 3.1 stumbles upon acceleration
CE light on or flashing? Check for codes?
If the car is not misfiring, could have a partially plugged cat...
Old 05-31-2012, 08:04 PM
CE light is not on, no codes have been stored and no mis-firing. Catalytic converter is not clogged either. Not sure what it could be. It's making me mental.
Old 06-03-2012, 02:27 PM
Ok, fuel pressure with key on is 41 psi. However, in one minute, it steadily drops to 34psi. Any ideas?
Old 06-03-2012, 06:00 PM
bcopeland bcopeland is offline
That sounds a lot like the 3.1 Malibu head gasket problems - check out that thread. And its the Fel-Pro trouble shooter intake gasket. It has metal on plastic - not plastic only like the originals used with that orange coolant crap.
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 12:16 AM
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 06:37 PM
2002 3.1 thermostat removal DigduG1975 Grand Prix 1 05-29-2010 08:47 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
3.1 interchange info please. Ponyak Grand Prix 2 06-08-2009 10:58 AM
