Old 05-29-2012, 07:22 PM
Traveling_Honda Traveling_Honda is offline
My car is in park and drive at the same time, so it will not start, what needs repaired?
When I go to start my car it has a solid red light around park, as it should, but it has a flashing green light around drive also. When this happens my car will not start. I usually try it a few times, wait and try and try again until it finally starts up. Once it starts the drives light is still blinking so I turn the car off and back on, then it is good to go. This does not happen every time, it seem sporadic. The engine, battery and oil light stay on, but I think it may only be because the car is starting up, usually the lights come on when starting then go off once the car is ready. Btw I drive a 1993 Honda Accord.
Old 05-29-2012, 07:41 PM
vgames33 vgames33 is offline
Re: My car is in park and drive at the same time, so it will not start, what needs repaired?
http://lmgtfy.com/?q=93+accord+drive+indicator+flashing
Seems to be a common issue. Flashing indicates an issue with the transmission controller. There should be a way to pull codes.
The Following User Says Thank You to vgames33 For This Useful Post:
Traveling_Honda (05-29-2012)
Old 05-31-2012, 09:07 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Could be something as simple as the neutral safety switch (sometimes called a manual lever position switch or Range selector switch).
Hit up a shop with free diagnosis. You can go to AutoZone too, but they usually have the cheap simple scanners that only read OBD2 codes. A shop will have a good code reader that reads Honda transmission codes and they can usually pinpoint the problem.
Dragging people kicking and screaming into the enlightenment.
Old 06-03-2012, 06:44 PM
bcopeland bcopeland is offline
There is a switch on the transmission that causes this problem. That or some plastic connecter.
99 cougar just quits driving down the road or will not start eeezeegoin76 Cougar 2 03-18-2011 07:05 AM
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
93 jimmy breaks down when warm and cut out sime time will not restart Confuzzed Jimmy 3 04-23-2006 04:35 PM
1995 Blazer will not start! I need help! irq_23 Blazer 5 12-30-2005 04:01 PM
