Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 05-27-2012, 08:18 AM
greasyhog greasyhog is offline
AF Premium User
RPMs jumping at highway speed
2000 neon automatic. My wife was complaining about the rpms jumping around when on the highway going about 65mph. The rpms are around 3000 and jump very slightly up and down and you can hear the engine tone change when it happens. Checked tran fluid and it was low about 3/4 of a quart and added some fluid, changed spark plugs and wires and the problem is still there. Doesn't happen all the time. She says it seems to only do this if the car has been sitting for a few hours or longer. There is an code for the downstream sensor which needs to be changed. Any ideas what the problem could be?
Old 05-27-2012, 02:37 PM
AF Premium User
Re: RPMs jumping at highway speed
I was thinking maybe the TPS. I tested signal wire with throttle closed and got a .722 volts. Then with wide open throttle I had a reading of 3.76 volts. The first reading seems high and the second seems low. Would anyone else agree with me here to replace the TPS?
Old 08-02-2012, 03:59 PM
AF Premium User
well the TPS wasn't the answer.....
Tach fluctuates 200 RPM at highway speed jtb74168621 S-10 4 05-07-2010 08:34 PM
Engine rpm increases @ highway speeds js216 Problem Diagnosis 4 03-28-2008 09:20 AM
high RPMs at highway speed philp1794 Grand Prix 17 01-27-2005 11:30 AM
Help requested: 2000 Jeep GRC rpms fluctuate at highway speed vonbraun Grand Cherokee | Grand Cherokee SRT8 2 03-17-2004 12:42 PM
RPM Surge or Jump at Highway Speeds (3000-4000rpm) jakeg1984 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 12-05-2003 12:59 AM
