Old 12-06-2004, 03:28 PM
philp1794 philp1794 is offline
high RPMs at highway speed
I'm having a problem with my '98 GTP. It's running high RPMs at highway speeds. Normally the car would run about 2100 RPM at 70 MPH. Now it is running about 3000 RPM at the same speed. This started about a week ago. It now also feels real sluggish at those speeds as well. When you step on the gas, it doesn't really want to go - very hesitant.
I've had it at the dealership a couple of times now for them to look at it. They haven't found anything that is wrong. They did do quite a bit of work on it though since it's at almost 100K miles. Most of it was normal maintenance stuff. It had the transmission fluid changed, coolant flush, tune up with new plugs, air filter, fuel filter, PCV valve changed.
I'm not getting any codes off the computer. They even tried updating the software on the computer to see if that would do anything.
Not sure where else to look, or what else to tell the dealership to look for.
Any ideas?
Old 12-06-2004, 03:36 PM
ericvrose ericvrose is offline
Your tranny may be slipping.
Old 12-06-2004, 04:46 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: high RPMs at highway speed
Wondering, how many times is it shifting? Is it going into overdrive?
Old 12-06-2004, 06:53 PM
dwalmop dwalmop is offline
maybe it is going into overdrive but tcc is not working properly???
Old 12-06-2004, 11:41 PM
94sportsedan 94sportsedan is offline
tcc lockup is usually only good for 3-400rpms drop, sounds like OD ain't kicking in.
Old 12-07-2004, 09:55 AM
I was guessing the same thing, that it wasn't shifting into OD. I'll have to listen to it again and see how many shifts it makes.
I don't think the tranny is slipping, it seems pretty smooth when it does shift. Is there a good way to tell if it is slipping?
After the software update the dealership did, it seemed to change where the hesitation is. It's now in the 45 MPH range instead of at the higher speeds. I wonder if the computer is having problems with the shift points? I talked to them again, and they want to do a full reload of the software again. Other than that, they still don't think anything is wrong. But it's still at 3000 RPM at 70 MPH.
Old 12-07-2004, 10:24 AM
Redhead 27 Redhead 27 is offline
Send a message via Yahoo to Redhead 27
Mine is doing the same thing. It won't go into OD, and the Torque converter isn't locking up. I am told, the TC slips, and the computer dis-engages OD, and the TC lock up.
When cruising, hit your brake pedal a small amount, and see if your RPM's increase about 300, and go down again, if it does that, your TC is locking up.
Old 12-08-2004, 06:09 PM
midwest meyham midwest meyham is offline
i'm gunna go with the OD not kicking in. be careful though. my tranny crapped out on me and it was doing the same thing.
Old 12-10-2004, 11:06 AM
I heard back from the mechanic. He said the transmission solenoid and valve assembly were getting too weak to shift into overdrive. So, it certainly appears to be a transmission problem. I should get the car back today. I'll post back if I this doesn't fix the problem.
Old 12-10-2004, 06:40 PM
post prices too. thanks
Old 12-12-2004, 02:13 PM
2000GPGTBlue2dr 2000GPGTBlue2dr is offline
Exclamation I just started having the same problem....
Hey Philip.
I went on the internet and did a search in Yahoo for rpm problems, and I found your post. Last night I noticed that my 2000 GP GT 3.8L was making a higher pitch rev noise at high speeds (60 or above) and then I saw that the tach shows rpm at 3000-3200 instead of the normal 2000-2500. Also, I wanted to ask.... Does your temp gauge run a little higher than usual?? Mine shows to be around 190 instead of the usual 175 or so- maybe this is related to the fact that the Overdrive is not kicking in. I first thought that my thermostat was going bad (maybe sticking), but I get plenty of heat inside my car, so maybe it's the transmission problem like you guys are saying this post. Anyway- let me know what you did to fix this- I hope it don't cost an arm and a leg to fix this!!!! Thanks to everyone for their information in the posts.....
Old 12-13-2004, 06:41 AM
OK, the things I've done to try and correct my problem, coming out of OD, and the TC not locking up.
Replaced the Shift solenoids, and the TC lock up switch=$450
Replaced the VSS sensor=$40
Replaced the cam sensor=$120
Retimed the cams(They were off)=did it myself
Replaced the TPS=$40
Replaced the IAC=$40
Had the tranny rebuilt, with a new TC=$950
I just bought this POS, dumped all this money into it, and it is still doing the same thing!!!!!!!!!!
I guess the ECM will be next!!!!!
Old 12-13-2004, 10:27 AM
Lightbulb More Transmission converter clutch info
A good test for overdrive is put the car in 3rd gear. Get up to highway speed (50-60mph), turn on cruise control, and then push the shifter into D. If the car does not change gears (like my car) then the Overdrive is not moving from 3rd to 4th gear.
This site does a good job explaining the Transmission converter clutch.
http://tech.oldsgmail.com/trans_TCC.html
It looks like Overdrive is controlled by the solenoid that gets a signal from the ECM to make the gear shift from 3rd to 4th. There are 2 wires that go to the solenoid- 1 for the 3rd gear and the other for 4th.
Old 12-16-2004, 02:41 PM
Sorry I didn't get back to this. The guy at the dealership replaced the solenoid and valve assemby. He also said he replaced the 4th gear clutch drive shaft. Total cost came to just under $1300. That's with all new parts.
The car runs much better now. I'm not having any issues with the RPMs or any shifting.
2000GPGTBlue2dr, I didn't notice if the temp was running higher. Of course, once this started I didn't really drive the car at highway speed very much. But that sounds like a good guess. If the engine has to work that much harder, it could run hotter.
Old 12-17-2004, 07:18 PM
Post
Phil,
One last thing. What were all the new parts that were replaced??? Was it just the solenoid, valve assembly, and the 4th gear clutch drive shaft?? Did they have to basically re-build the transmission??? How did they get to these parts to replace them, in other words, did they have to remove the transmission, or were the parts accessible from opening up the bottom pan?? I wanna get an idea of everything they did for the $1300....
I took it to a shop and they did a diagnostic test and they found no transmission codes, and I had them change the transmission filter 'cause I never had transmission service before- since I bought the car.
I'm so pissed, man. Even though the car does go into overdrive, I hate driving on the freeway cause the transmission is not going into 4th gear when I press the accelerator at highway speeds- it only goes into overdrive when I release the accelerator. So I hit the gas and it goes to 3000-3400 rpm, and when I release it drops down to 1800 rpm- and my fuel economy went down as well, along with the temp gauge reading higher than usual- this sucks!!!!
